Glue-up - What sequence works best?
« back to Joinery forum
Forum topic by fsutim posted 04-18-2016 12:17 AM 701 views 0 times favorited 3 replies Add to Favorites Watch
View fsutim's profile
fsutim
17 posts in 1101 days
04-18-2016 12:17 AM
I was curious if I was gluing a tabletop with four boards approximately 10 inches each which order should I glue the boards together for the best results. In the past I have glued board 1 and 2 together as well as board 3 and 4 together making two seperate boards. Once they are dry I combine the two together to make the table. Is this the best order or is there a better sequence? I appreciate any input!
3 replies so far
View saw4fun's profile
saw4fun
176 posts in 3335 days
#1 posted 04-18-2016 12:46 AM
If they are perfectly flat I don’t know that it would matter. I don’t have a big jointer so I make my center panel 18” with rough cut then run through the planer after dry and then add the side pieces on. Don’t know if this helps but it works for my set-up..
View waho6o9's profile
waho6o9
8188 posts in 2572 days
#2 posted 04-18-2016 12:59 AM
http://www.mikes-woodwork.com/Cauls.htm
If you have the clamps and cauls I’d make the whole thing at once.
HTH
View TheFridge's profile
TheFridge
9444 posts in 1481 days
#3 posted 04-18-2016 01:19 AM
Maybe alternate grain?
Like /\/\
