Resolved: Jet JWP-15CS 3HP motor start capacitor
Forum topic by Holbs posted 04-17-2016 05:06 AM 1234 views 0 times favorited 5 replies Add to Favorites Watch
View Holbs's profile
Holbs
1878 posts in 2058 days
04-17-2016 05:06 AM
Topic tags/keywords: start capacitor
Finally getting back in the shop after a month hiatus. I’ve been working on new blast gates and my Jet 15” planer motor woes. Last month, I went to turn on the planer. The motor hummed but no belts turned. Oh crap… I can not afford a new 3HP motor. So, investigation and research time…
I come to find out, the #1 reason for a motor hum/does not work is the start capacitor: thankfully, an easy and cheap thing to fix. To first find out, I bought a capacitor tester from Amazon for $17. This is no Fluke tester but seeing how I may test a capacitor or 2 once every 40 years, I felt this was a good choice. And here is the first test. It should be hovering near 500 but instead it hovers down in the 350’s. Not so good:
The Jet 3HP motor has a start capacitor of 500 MFD. I took this unit down to my local motor repair place (the kind of place that rewinds motors and mostly work on 3phase boys). And they verified it was a faulty capacitor. Oddly enough, there were no physical / visual identifiers of it being bad. A tester was the only method. They sold me a somewhat similar brand with different terminals. Brought it home, and this was the test:
Hooked it all up and the motor starts flawlessly. Whew. Now to re-install back into the planer. Just wanted to let other LJ’s know about start capacitors and easy/cheap fixes.
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
5 replies so far
View knotscott's profile
knotscott
8057 posts in 3404 days
#1 posted 04-17-2016 11:38 AM
A job well done!
Holbs
#2 posted 04-17-2016 04:04 PM
Oh…I guess I should toss in that the Vanguard capacitor was $22. I could of went the amazon or $8 online route, but this was an area I am not comfortable with and went with the pro’s recommendation.
View JoeinGa's profile
JoeinGa
7736 posts in 2035 days
#3 posted 04-20-2016 05:30 PM
Good for you.
You dodged a bullet on that one !
View Redoak49's profile
Redoak49
3289 posts in 2017 days
#4 posted 04-20-2016 07:34 PM
Very good…always great to hear how someone solved a problem.
View Underdog's profile
Underdog
1116 posts in 2064 days
#5 posted 04-20-2016 07:39 PM
I had the same thing happen on several JET 1014 mini lathes I’ve turned with. I tried using an aftermarket capacitor, but fried it immediately.
In the long run it was cheaper to buy one from Jet. As long as it was a phone order that is. Ordering online the shipping was $20, while the part was only $11, and weighs less than an ounce…Phone order shipping was about $10.
