What glue for Boulle work marquetry
Forum topic by madburg posted 04-17-2016 03:08 AM 648 views 0 times favorited 2 replies Add to Favorites Watch
View madburg's profile
madburg
204 posts in 840 days
04-17-2016 03:08 AM
Topic tags/keywords: gluing boulle work veneering
I am about to embark on a series of boxes that will be covered with Boulle work marquetry. So the marquetry panels will include brass sheet, pewter sheet, faux tortoise shell (celluloid sheet) and the usual wood veneer.
The old texts suggest fish glue, and to rub/clean the marquetry panels surface with garlic before applying the glue and pressing. This is all good for a totally traditional approach, or for the restoration/conservation of antique pieces. Judging by the amount of Boulle that needs restoring, all be it after 200 years or so, due to the marquetry panels lifting, there must be a modern glue that should do the job, and last some what longer.
The glue needs to be able to give a little to allow for the differential in the expansion/movement of the different materials in the marquetry panel.
Cold cure epoxy comes to mind as any heat would encourage the brass and pewter to expand only to shrink as it cools down. But which brand/make.
So ….............. what other suggestions, or first hand experience is there out there?
-- Madburg WA
2 replies so far
View TheFridge's profile
TheFridge
9458 posts in 1483 days
#1 posted 04-17-2016 03:16 AM
Look up Shipwright’s blogs and projects
View mousejockey's profile
mousejockey
68 posts in 2940 days
#2 posted 04-17-2016 03:23 AM
you might give Patrick or Patrice a try at
http://www.antiquerefinishersinc.com/
