Tile over Particle Board
Forum topic by plang posted 03-21-2010 07:51 PM 12437 views 0 times favorited 7 replies Add to Favorites Watch
View plang's profile
plang
116 posts in 3261 days
03-21-2010 07:51 PM
Do I need to take any steps to prepare Particle Board for covering it with Ceramic Tile? Will the PB react in anyway to the tile addhesive, or should I use a different base? Thanks
7 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 2975 days
#1 posted 03-21-2010 08:00 PM
Particle board or flakeboard will work for a tile substrate, but I would recommend using a 1/4” or 1/2” cement board like Hardi Backer.
View fredito's profile
fredito
27 posts in 3596 days
#2 posted 03-21-2010 08:09 PM
If you tile directly over it you risk having the partical board swell with the moisture in the thinset, not likely, but possible. It is recommend to use a backer such as Hardibacker…about the only exception for direct application of tile is to cement and backsplashes…Hardibacker will also help with possible cracks that may form along the joints of the pw…also they make a special tape (in the tile dept) for the seams of hardi…its about $5 a roll…it looks like dw tape but dw tape will break down with thinset…the 1/4 in is for flooring/countertops the 1/2 is mostly for walls so it sits flush with drywall…also if you use hardi they make a little cutter, $9, its way better then using a utility knife…the hardibacker website has quite abit of info on all of this….Hope all of this helped
View bill1352's profile
bill1352
130 posts in 3028 days
#3 posted 03-22-2010 03:15 AM
If your tiling a table top I’d use MDF. as noted any mosture can cause particle board to swell and even separate.
-- Keep Your Stick On The Ice
View Dark_Lightning's profile
Dark_Lightning
3068 posts in 3015 days
#4 posted 03-22-2010 03:53 AM
If you use particle board, you can expect cracking in the tile and/or grout unless you are laying it on a slab- which you wouldn’t want to do- you’d just set it on the slab, not the particle board. I’d recommend a serious t&g plywood, say 2-1/8”, as a minimum. And even then, if I were doing it in a wet area, I’d still lay a cement board on it. You want the floor as stiff as possible to avoid cracking.
-- Random Orbital Nailer
View dbol's profile
dbol
136 posts in 2904 days
#5 posted 03-22-2010 12:28 PM
You can not tile over particle board and expect it to last. If you want to keep the weight down use Ditra. A product by Schluter. They have it at HD.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3387 days
#6 posted 03-22-2010 02:36 PM
I would use MDF also.
-- Wayne - Plymouth MN
View Moron's profile
Moron
5032 posts in 3800 days
#7 posted 03-22-2010 02:43 PM
plywood
