de-glue two ply
Forum topic by williams posted 03-21-2010 06:07 PM 1340 views 0 times favorited 7 replies Add to Favorites Watch
View williams's profile
williams
53 posts in 3017 days
03-21-2010 06:07 PM
Topic tags/keywords: ply titebond
I made mistake L section of bar top. I have to remove 2’ piece of 3/4 CTX ply that was glued to 3/4 particle board using titebond. Am I going to be able to split these apart – or will I just create a mess? I wanted to x-cross the layers at the L, but forgot to leave top ply piece shorter for the overlap.
-- William, Brighton, MI
7 replies so far
View JAGWAH's profile
JAGWAH
929 posts in 3084 days
#1 posted 03-21-2010 06:13 PM
You might, but then I’d just saw kerf the 2” edge multiple times at a just shy proper depth, break away the waste and then chisel or route to a clean bottom. I would consider using draw-tite anchors to pull the two together.
-- ~Just A Guy With A Hammer~
williams
#2 posted 03-21-2010 06:21 PM
@jagwah. Thank you. I am not familiar with the loc-tite anchors. Any link on those? tia
View hazbro's profile
hazbro
109 posts in 2990 days
#3 posted 03-21-2010 06:43 PM
the glue bond will be stronger than the particle board and make a mess. you could cut a rabbet in the top side of the glued down board and the bottom of the next board to make a lap and screw them together.
-- measure once, keep cuttin' til it fits
williams
#4 posted 03-21-2010 06:52 PM
@haxbro. That is another good thought. thank you.
View Peter Oxley's profile
Peter Oxley
1426 posts in 3874 days
#5 posted 03-21-2010 07:02 PM
@williams – here are links to a couple of products for connecting countertop sections. I like the FlipBolts.
QuickDraw Countertop Connector
FlipBolt Countertop Connector
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
JAGWAH
#6 posted 03-21-2010 07:03 PM
Sometimes called draw-tites loc-tites or zip bolts like these at Mc Feelys.
http://www.mcfeelys.com/product/FSC-2600/Zipbolt
Here’s a do it yourself site showing use of the ones I’m more familiar with
http://www.hammerzone.com/archives/kitchen/countr/install2.html
View FirehouseWoodworking's profile
706 posts in 3273 days
#7 posted 03-22-2010 12:50 AM
You can also usually find the draw-tite bolts at Home Depot or Lowes where they sell the pre-made countertops.
-- Dave; Lansing, Kansas
