Advice on this CL bandsaw
Forum topic by bayouwood posted 04-15-2016 04:15 PM 948 views 0 times favorited 10 replies Add to Favorites Watch
View bayouwood's profile
26 posts in 844 days
04-15-2016 04:15 PM
I REALLY want a band saw for resawing logs and this gem popped up right down the road from me:
The seller doesn’t seem that knowledgeable on it. He bought it from the original owner and hasnt ever used it. Just sat there.
He doesn’t know the model and says its too scratched to read. He says it runs perfectly fine, but it is missing the bearing blade guide, as well as a fence.
I have been googling around and these items seem like they might be kind of hard to track down…. unless I am overthinking it and there are universal options. If anyone has suggestions for this I am all ears.
$400 a good deal in its current state? i usually hate to offer less because it makes me feel like a scam artist but theres always that option. Either way I’m going to go check it out tonite.
10 replies so far
View hairy's profile
2624 posts in 3463 days
#1 posted 04-15-2016 04:23 PM
I think it’s too high, it’s missing parts. I wouldn’t pay over $150. It looks like a Delta clone, parts may or may not interchange.
-- My reality check bounced...
View conifur's profile
955 posts in 1083 days
#2 posted 04-15-2016 04:28 PM
Label sez Grizzly on it, if I am reading it right. 18”, in my market on CL that is about the right price. It would be a bit high for a 14”, which are the most common around by me on CL.
View SASmith               's profile
1850 posts in 2918 days
#3 posted 04-15-2016 04:31 PM
That is a high price for my area, not sure about yours. I bought a fully functional one just like it for $150. It takes up to a 1 1/2” wide band. Mine has a a 2 HP motor. No parts are available through grizzly. The weak point is the upper wheel mount/ tensioner. It is thin cast aluminum or “pot metal”. Mine broke and I fabricated a 1” thick solid aluminum replacement.
-- Scott Smith, Southern Illinois
#4 posted 04-15-2016 06:12 PM
yea after looking at prices of both a kreg fence and blade guide, this is overpriced in my opinion. I would rather wait til a better deal comes along
View TheFridge's profile
9066 posts in 1417 days
#5 posted 04-15-2016 06:27 PM
250$ max depending on market.
View Woodknack's profile
11293 posts in 2311 days
#6 posted 04-15-2016 07:25 PM
I tell people, ‘I don’t know what it’s worth but here’s what it’s worth to me’. I give them my price. If they don’t like it, we both move on with life.
-- Rick M,
View Kenlew's profile
3 posts in 1342 days
#7 posted 04-16-2016 04:42 AM
If it were me, I’d take the $400 and pick up an older model Delta. You should be able to find a decent one for $400.
-- Ken
View TMGStudioFurniture's profile
55 posts in 750 days
#8 posted 04-16-2016 05:10 AM
My experience in buying used tools is that they always need some repair and parts – always, every time.
So, for me, parts availability is a top priority, which is why I like more ‘common’ machines. Common machines use common parts, rare machines take rare parts – that’s pretty much all you need to know.
I think that 18” saw is a bit of an oddity, and I think you are smart to pass on it, especially if Grizzly cannot supply parts for it. If you can’t make it run right, then to me it isn’t worth anything.
View rustfever's profile
746 posts in 3241 days
#9 posted 04-16-2016 10:04 AM
I had the same brand/model saw. Would not work correctly or cut consistently. Could never adjust and keep any settings. Could not find replacement parts. Gave the saw away.
I have a Laguna now. SUPER. Would never consider parting with the Laguna.
Save your money. Even free is too much.
-- Rustfever, Central California
View ThomasChippendale's profile
244 posts in 863 days
#10 posted 04-16-2016 02:33 PM
To resaw logs you need HP, rigidity for blade tension and throat clearance. My laguna 14 SUV has all of these + a carbide one inch blade and cuts nicely and straight through logs using a sled. An 18 inch bandsaw needs to be a lot beefier to get the rigidity of a 14 inch. I would go towards the older general, deltas and powermatic 18-20 inches found in commercial workshops and older woodworking industries if I wanted to resaw logs.
-- PJ
