What wood type is appropriate for creating custom inlays?
Forum topic by jakenh posted 04-15-2016 04:14 PM 696 views 0 times favorited 3 replies Add to Favorites Watch
View jakenh's profile
jakenh
3 posts in 1013 days
04-15-2016 04:14 PM
Topic tags/keywords: wood type inlay wood selection
For example, I want to create an inlays of my fiancee’s initials for a cutting board I am making for her. For the inlay pieces, however, I’m not sure what wood I should use. Because I am a slight beginner and don’t have many tools I will be using a jigsaw to cut the inlays out and a plunge router to make the inlay-points on the actual cutting board.
Which wood types would be appropriate for creating these inlays? I know they’ll need to be relatively thin, but that’s all I know.
-- Jaken Herman
3 replies so far
View DerekJ's profile
DerekJ
100 posts in 1128 days
#1 posted 04-18-2016 05:14 PM
I’m not an expert by any means, but I would think that you can use any type of wood you want for an inlay; and as far as thickness goes, it just needs to be thinner than your overall thickness. If you have a 3/4” cutting board, you could use an inlay that is 1/4” thick without too much trouble, even a 1/2” would work. You just have to make sure your jigsaw and router work is very precise.
I would recommend using a smaller router bit than needed and finishing the route with a chisel to get it exact.
-- Derek ~ Omaha, NE
View Jim Finn's profile
Jim Finn
2688 posts in 3162 days
#2 posted 04-19-2016 12:23 PM
I suggest that you consider “Double bevel inlay” using a scroll saw. I do a lot of it and it is quick and easy.
-- No PHD just a DD214 Website> craftingcouple.com
View DrDirt's profile
DrDirt
4526 posts in 3982 days
#3 posted 04-19-2016 02:32 PM
Yep – - pretty much any wood.
I would avoid softwood… you can also do do colored epoxy inlay.
