How can I stabilize my dresser?
Forum topic by king_nickizzle posted 04-14-2016 08:43 PM 2064 views 0 times favorited 10 replies Add to Favorites Watch
View king_nickizzle's profile
king_nickizzle
27 posts in 1152 days
04-14-2016 08:43 PM
Topic tags/keywords: wood dresser stable stabilize
I’m making a simple 6 drawer mid century modern dresser using 1/2” birch plywood. I used pocket holes to attach everything. I’m nearing the end and I’ve noticed it sways left and right very easily. It’s as if my rectangle design can be turned into a parallelogram by just lightly giving some force on one side. What can I do at this point to stabilize it?
I haven’t put a back on yet so that may help some, but I have a feeling that won’t totally solve it. Anyone have tips? I tried putting a l by 4 across the top inside, but that doesn’t really seem to do much.
10 replies so far
View DanK's profile
DanK
26 posts in 2907 days
#1 posted 04-14-2016 09:02 PM
Adding the back will stiffen things up quite a bit. You could add a horizontal brace between the drawers.
king_nickizzle
#2 posted 04-14-2016 11:58 PM
Thanks DanK!
I’ve put a 2 by 4 on each side towards the bottom and that seemed to help. I will do one more towards the top on each side and also the back. I’m feeling more confident about this piece now!
View jumbojack's profile
jumbojack
1685 posts in 2864 days
#3 posted 04-15-2016 04:15 AM
Your improvements and a back will solid your dresser up nicely.
View DrDirt's profile
DrDirt
4526 posts in 3982 days
#4 posted 04-15-2016 03:56 PM
^^ Yep. think about even a sheet of cardboard. grab it by the edges and try to make that rectangle a parallelogram
for the ‘applied’ versus ‘set in a grove like a drawer bottom’
tack it at one edge, then square the case and tack the opposite edge, then finish fillin in with the rest of the nails/screws ?? to attach the back solidly.
View pintodeluxe's profile
pintodeluxe
5819 posts in 3053 days
#5 posted 04-15-2016 04:05 PM
I have been impressed with how simple dado joints stiffen up a case. I’m sure a back will make this project solid, but in the future consider using dados and glue. 3/4” sides will also add significantly to case rigidity.
king_nickizzle
#6 posted 04-16-2016 12:21 PM
Thanks everyone! The back did indeed help tremendously! I do agree with using dados next time, I think that would save me a lot of headaches.
View dhazelton's profile
dhazelton
2805 posts in 2537 days
#7 posted 04-16-2016 12:27 PM
I would have used 3/4 for the carcass.
View Monte Pittman's profile
Monte Pittman
30153 posts in 2578 days
#8 posted 04-16-2016 12:38 PM
A good back is essential.
king_nickizzle
#9 posted 04-22-2016 01:07 PM
Thanks guys! I was contemplating 3/4”, but I was going for a very sleek look. But I think it’s worth the small sacrifice for next time in order to have a more structurally sound piece.
View Waldo88's profile
Waldo88
207 posts in 1537 days
#10 posted 04-22-2016 03:57 PM
Even using 1/2” ply, well done glued dadoes will be very stiff, but that is still secondary to the reinforcing the back adds.
Pocketholes just aren’t very strong, compared to glue there really is no comparison.
