Spindle Taper on Pen Mandrel Is Hot
Forum topic by RichCMD posted 04-14-2016 07:55 PM 364 views 0 times favorited 1 reply Add to Favorites Watch
View RichCMD's profile
RichCMD
393 posts in 1847 days
04-14-2016 07:55 PM
Topic tags/keywords: lathe pen mandrel spindle taper turning
I have a Jet JWL-1221VS lathe, and I have been concerned about it for a while. It seems to me that is nosier than it should be, but I am not sure what is causing the noise. It also seems that sometimes I get some vibration when using a pen mandrel, but I am not sure if that is from the lathe or the mandrel.
Today I noticed a new wrinkle. When I removed a pen mandrel from the lathe, the spindle taper on the mandrel was pretty warm. I can’t recall ever before noticing the spindle taper on the mandrel getting warm. I had just completed running at max speed while applying a friction finish.
My question is, have you ever noticed the spindle taper on your pen mandrel heating up?
-- Ride the bevel!
1 reply so far
View Wildwood's profile
Wildwood
2240 posts in 2040 days
#1 posted 04-14-2016 08:17 PM
No! Have one MT2 universal mandrel from Packard Woodworks (PSI reseller) and MT2 A & B mandrel from Berea Hardwoods.
Do you notice pen your pen barrels out of round? Could be over tighten knurl nut or over tighten live center in tailstock.
You could have lathe bearings going bad, or hand wheel that is loose making noise.
Let us know what you find out.
-- Bill
