Anyone use HTC mobile bases for their tablesaws?
Forum topic by jayjay posted 03-20-2010 01:21 AM 2918 views 0 times favorited 11 replies Add to Favorites Watch
View jayjay's profile
jayjay
639 posts in 3040 days
03-20-2010 01:21 AM
Hey fellas-
I’m in the market to pick up a mobile base for my unisaw, and I’d like to get your valued opinions. I’m tired of dragging my tablesaw around my garage back and forth, so I’m going to finally break down and buy a mobile base unit for it. Anyway, I’m interested particularly in the HTC-3000, it seems to be decent for what I need it for. Do any of you have any experience with HTC products? Pros/Cons/Yay/Nay. My main concern it durability and function.
Here is a link
http://htcproductsinc.com/umb.html?keyword=htc&langId=-1&storeId=10051&catalogId=10053
Thanks.
-- ~Jason~ , Albuquerque NM
11 replies so far
View hairy's profile
hairy
2701 posts in 3526 days
#1 posted 03-20-2010 01:50 AM
I don’t know about that one, but I’m using this one:
http://lumberjocks.com/hairy/blog/11363
-- My reality check bounced...
View jack1's profile
jack1
2107 posts in 4021 days
#2 posted 03-20-2010 02:29 AM
They make a good unit. I have all my stationary tools that didn’t come with one (table saw, band saw, router table, joiner, scroll saw, mortiser, v drum sander…) on them. Lots of nuts and bolts and the rails are adjustable. Good stuff.
jayjay
#3 posted 03-20-2010 03:26 AM
Thanks for the feedback. If this works out good, I’ll probably pick up a couple more for some other machines.
hairy,......that’s a pretty slick set up you have there.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3474 days
#4 posted 03-20-2010 03:55 AM
I dont happen to have an HTC, but I have heard good things about them. Most of the mobile bases I have are Jet. I have one for my RAS that has steel corners with wood for stringers. That one works good too.
Most bases have a load weight rating so if you stay in the correct load range you should be in good shape.
-- Wayne - Plymouth MN
View JerrySats's profile
JerrySats
237 posts in 3604 days
#5 posted 03-21-2010 02:57 AM
I have the HTC 3000 , I got it when I bought my 18” bandsaw .The saw weights in at 450lbs . So the base is capable of holding it , however I didn’t like it . Not surefooted enough for me when down off the wheels . I recently purchased a Performax 16/32 and put it under that . I would get a base sized for your TS , if you have a woodworking store close by stop in a test drive some . I think all your questions would be answered by trying the different mobile bases out .
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3521 days
#6 posted 03-21-2010 06:41 AM
For the price I paid for the HTC and two other brands I will make them in the future. Not solid, too low to the floor for easy moving, flimsy at best and if they didn’t say different I would swear they were made in China. Never again…
jack1
#7 posted 03-21-2010 07:55 AM
If you tighten everything, they are not flimsy and will park as solid as a tank if you adjust the stoppers correctly. I’ve made mobile bases and by the time you get good wheels, decent wood and all they time required to design, make and tweak your unit, you could’ve bought 3 HTC’s or some such product if you time is worth anything…
View 559dustdesigns's profile
559dustdesigns
633 posts in 3162 days
#8 posted 03-21-2010 12:47 PM
There is one on my friends table saw that’s at my place. I give it a 4 out of ten. It does the job and has not come apart. This base has two levelers on the side that are rather flimsy and just not robust or adequate enough for my use. The rubber has come off. This universal base doesn’t fit the saw very well. It may not be for this saw. The best wheels on a table saw are those integrated into the pm2000 Powermatic cabinet saw. I wish they made a universal set like that.
-- Aaron - central California "If you haven't got the time to do it right, when will you find the time to do it over?"
View ND2ELK's profile
ND2ELK
13495 posts in 3768 days
#9 posted 03-21-2010 01:57 PM
I did a review on these if you care to look. I have the 3000 unit under my jointer/planer. All my other stationary equipment is using the 2000 units. Some people do not like them but I have had no problems with mine what so ever and feel they are a great unit.
God Bless
tom
-- Mc Bridge Cabinets, Iowa
View Vincent Nocito's profile
Vincent Nocito
485 posts in 3358 days
#10 posted 03-21-2010 01:59 PM
I use them on lighter tools (bandsaw, jointer and router table). Use a heavy duty Shopfox base for my TS. No real complaints with the HTC bases for the job that they are assigned.
View gmal1's profile
gmal1
6 posts in 2994 days
#11 posted 03-23-2010 04:05 AM
I have had an HTC under my cast iron Sears TS for 10 years. Very solid, nothing ever came loose, and I can move the saw whenever I need to.
