Shop over asphalt basketball court
Forum topic by FlagshipOne posted 04-13-2016 06:23 PM 1043 views 0 times favorited 14 replies Add to Favorites Watch
View FlagshipOne's profile
FlagshipOne
12 posts in 2327 days
04-13-2016 06:23 PM
considering the purchase of a home that has a basketball court in the backyard. am going to build my new shop in the space but was wondering ….. would it be best to elevate the floor joists above the asphalt or can I set them down right on top of it? is there something that i can place between the wood and asphalt to keep it from rotting?
-- Some Dood in Virginia
14 replies so far
View gargey's profile
gargey
980 posts in 773 days
#1 posted 04-13-2016 06:50 PM
Yes/No. Yes.
View AZWoody's profile
AZWoody
1330 posts in 1222 days
#2 posted 04-13-2016 07:07 PM
I would think the asphalt could be surfaced to make it smooth to make the floor of the shop.
Many tennis courts are asphalt and just have a coating to make the court smooth.
Unless you want to run cabling and ducting under the floor, I would look into that.
View Woodknack's profile
Woodknack
11626 posts in 2378 days
#3 posted 04-13-2016 08:06 PM
Agree with gargey, yes, no, yes. There are some outstanding shed building tutorials on youtube, I watched one whole series and don’t even have plans on building a shed but it was so well made. Anyway, those videos will answer all your questions and many you didn’t know to ask. Only thing I can add is that for a workshop I’d put the floor joists 12” on center and go with the tallest ceilings you can.
View conifur's profile
conifur
955 posts in 1149 days
#4 posted 04-13-2016 08:11 PM
Does the ground freeze by you in the winter? If so you might need footings.
View Ocelot's profile
Ocelot
1975 posts in 2636 days
#5 posted 04-13-2016 09:08 PM
I doubt the basketball court is as flat and level as you will want your floor to be. Just a thought.
View builtinbkyn's profile
builtinbkyn
2278 posts in 938 days
#6 posted 04-13-2016 09:24 PM
There are a few ways to do this, but I probably wouldn’t bear directly on the asphalt. If you’re in a frost zone, it may heave in areas that aren’t under load from the structure and if you’re in a hot climate, the weight of the structure may cause it to give way and sink. I’d excavate in strategic locations to pour concrete piers and then frame as usual.
-- Bill, Yo!......in Brooklyn & Steel City :)
View crank49's profile
crank49
4030 posts in 2969 days
#7 posted 04-13-2016 10:02 PM
A home I recently remodeled had a den addition built on top of a concrete patio.
The floor joists were sitting directly on top of the concrete with some shims to level it up.
This construction had been in place since 1960 with the only known problem being some roof leaks caused, I think, by uneven expansion between the house and the “on top of patio” addition.
In the case of asphalt, all the already mentioned cautions would apply. Depends on your location and your local codes.
If you are lucky enough to live in an area that is still free from intrusive government regulation and have a mild climate you might be able to lay pressure treated joists on the asphalt and get away with it. Don’t forget to consider rain water intrusion. Water would be my biggest concern.
conifur
#8 posted 04-13-2016 11:06 PM
If you are lucky enough to live in an area that is still free from intrusive government regulation and have a mild climate you might be able to lay pressure treated joists on the asphalt and get away with it. Don t forget to consider rain water intrusion. Water would be my biggest concern.
- crank49
If you did that and no footings supporting the patio slap, and connected it to the house thats what happens.
View bruc101's profile
bruc101
1200 posts in 3539 days
#9 posted 04-13-2016 11:45 PM
- Ocelot
We’ve got an asphalt half basket ball court and a full tennis court all on the same surface.The surface is not dead flat so water can run off of it and when ice and snow melt it helps to let it run off.
Personally, I don’t think I would set floor joist on it because it does move with temperature change. Because of that we have to get it resealed about every two years. If we didn’t it would get cracks in it.
-- Bruce Free Plans http://plans.sawmillvalley.org
crank49
#10 posted 04-14-2016 01:48 AM
- crank49
- conifur
To start with I’ll assume you meant “patio slab” instead of “patio slap”.
More to the point, I DID NOT say I built anything on the slab. I specifically said it was done in 1960. Hell, I was not even in high school till 1963. I simply observed it had been done and differing expansion of different foundation systems could create problems.
In fact, I demolished the patio topper, excavated a proper footing, pumped in concrete, and built a new master bedroom suite with a marble spa bathroom in its place.
117091 posts in 3575 days
#11 posted 04-14-2016 03:41 AM
As a 30 year contractor ,I would say it has to do with what size shop you’re going to make,a small shop say storage shed size(say 10’x12’) on blocks Might work out and might not,if the soil is expansive and or if the asphalt is thin which it is much of the time. If you have the funds I’d say you’ll be better of with a traditional footing and stem wall foundation or even pole barn construction if your codes allow them.
View clin's profile
clin
841 posts in 994 days
#12 posted 04-14-2016 01:03 PM
I think asphalt is too soft to build on. I’d plan on real footings and a real floor, either a concrete slab or joists. And, I wouldn’t rely on the asphalt to support the floor.
Building a shop is real work and a serious investment. Do it right so it lasts and adds value to the property. Do it poorly and have it sag and fail and lower your property value.
-- Clin
View ClammyBallz's profile
ClammyBallz
434 posts in 1134 days
#13 posted 04-14-2016 03:57 PM
What clin said!
There’s a good reason why highways are made of concrete instead of asphalt. Eventually the asphalt will sink where your heavy tools are located.
View splatman's profile
splatman
586 posts in 1397 days
#14 posted 04-14-2016 06:18 PM
Build the footing and stem wall around the court, and pour the concrete floor on top of the court. The only problem that might arise is the soil under the court might compress under the weight of the slab, causing settling.
If building a wood floor, the court can be the crawlspace floor.
