Reliant planer feed roller problem--HELP
Forum topic by turnwooder posted 04-13-2016 02:35 AM 1108 views 0 times favorited 3 replies Add to Favorites Watch
View turnwooder's profile
turnwooder
5 posts in 3301 days
04-13-2016 02:35 AM
Topic tags/keywords: reliant planer feed roller
I have acquired an elderly Reliant 15”planer. Problem is the feed rollers do not carry the work piece through the planer. Everything appears to work. The rollers turn but the board doesn’t advance. Does anyone have an idea for a solution?The rollers are stainless steel and appear to be just turning against the wood without moving the wood.is there supposed to be some kind of covering (like sandpaper maybe )on the roller to create friction to grab the wood? Any guesses would be greatly appreciated.
-- Turnwooder
3 replies so far
View MadMark's profile
MadMark
979 posts in 1420 days
#1 posted 04-13-2016 04:19 AM
Wax the feed trays …
M
View rick1955's profile
rick1955
264 posts in 1397 days
#2 posted 04-13-2016 03:36 PM
Doubt the rollers are stainless. Wax the bed. Have you checked the feed roller height? When will you folks give more info on what you checked and more details on your posts??
-- Working smarter with less tools is a true crafts person...
View pintodeluxe's profile
pintodeluxe
5622 posts in 2780 days
#3 posted 04-13-2016 05:14 PM
Mechanical problems notwithstanding, dull knives is the usual culprit. As the knives become dull, the feed pressure becomes too great for the rollers. They begin to slip and can no longer force the board through.
Waxing the table helps for a while, and should be done regularly. However new knives will make all the difference.
Also make sure depth of cut is minimal.
