Forstner bit rotational sped
Forum topic by lovinmrv posted 03-18-2010 02:40 PM 1783 views 4 times favorited 9 replies Add to Favorites Watch
View lovinmrv's profile
lovinmrv
101 posts in 3023 days
03-18-2010 02:40 PM
Topic tags/keywords: forstner bit rpm drill speed resource question
Is there an optimal RPM setting for forstner bits and, if so, what is it?
Apologies if this is already covered…I haven’t been able to find it.
Thanks
-- Life is a sales job.
9 replies so far
View davidpettinger's profile
davidpettinger
661 posts in 3164 days
#1 posted 03-18-2010 02:53 PM
http://www.ibiblio.org/twa/info/drillSpeedChart.pdf
lovinmrv, Use this chart. Has all the necessary drill speeds you need.
-- Methods are many,Principles are few.Methods change often,Principles never do.
View Chase's profile
Chase
448 posts in 2990 days
#2 posted 03-18-2010 02:59 PM
Fantastic chart UnionLabel, That is getting printed out and possibly laminated for my shop as soon as I get home.
-- Every neighborhood has an eccentric neighbor. I wondered for years "who was ours?" Then I realized it was me.
View DaddyZ's profile
DaddyZ
2475 posts in 3004 days
#3 posted 03-18-2010 03:21 PM
Excellent Chart – done saved to favorites !!
View richgreer's profile
richgreer
4541 posts in 3038 days
#4 posted 03-18-2010 03:31 PM
! agree, the chart is great. I have a similar chart on my wall by my drill press.
The problem is that some drill presses just don’t go slow enough for the big Forstner bits. (I use bits up to 3”).
My advice on drilling large holes is to do it in stages. Clamp the piece securing in place and start with a 1” bit. Then drill again with a 1.5” bit and continue until you have the size you want.
lovinmrv
#5 posted 03-18-2010 03:53 PM
wow…awesome, jocks! Thanks!
View PineInTheAsh's profile
PineInTheAsh
404 posts in 3231 days
#6 posted 03-18-2010 04:23 PM
Rich’s “in stages” suggestion (among many eloquent submissions here) is on mark.
Here’s much love to the beautiful gimlet-point bit.
I don’t have a 3” Forstner bit though have played with my 2-1/8” and then jig saw and chisel my way to satisfaction. One day soon am compelled to have a complete Forstner bit of every size they make; the bit design is one of the greatest woodworking inventions ever.
Here’s to the inventive Benjamin Forstner.
—Peter
View SPalm's profile
SPalm
5317 posts in 3845 days
#7 posted 03-18-2010 05:40 PM
Just another thought. Heat will kill these things. So turn it slowly, and lower it slowly. In fact, raise it up and let it cool if you are cutting a deep hole.
There are a lot of really cheap sets of these on the market. They may look alike, but there is a reason that the price differences are there.
Steve
-- -- I'm no rocket surgeon
View Chris Wright's profile
Chris Wright
540 posts in 3445 days
#8 posted 03-18-2010 06:11 PM
My set of bits have the max speed engraved on the shank. None are show a max speed of over 800 RPM. The larger ones say 650 RPM max. The speed I use on my drill press is in the mid 500’s (if the diagram on the inside of the pully cover is correct).
-- "At its best, life is completely unpredictable." - Christopher Walken
View Sawkerf's profile
Sawkerf
1730 posts in 3032 days
#9 posted 03-18-2010 07:11 PM
Drill speed (rpm) is only part of the picture. A lot also depends on the wood you’re working with, the sharpness of the bit, and the feed rate (downward pressure) you’re using.
Use the chart(s) to set your initial speed, but “tweak” it if you need to.
