Comet II lathe
« back to Woodturning forum
Forum topic by gpryon posted 04-11-2016 12:58 PM 731 views 0 times favorited 8 replies Add to Favorites Watch
View gpryon's profile
gpryon
6 posts in 1130 days
04-11-2016 12:58 PM
The variable speed stopped working. Is stuck on high. Any ideas on how to repair?
Thanks
-- gpryon
8 replies so far
View HapHazzard's profile
HapHazzard
116 posts in 835 days
#1 posted 04-11-2016 11:32 PM
Say more words. Does the knob turn? When did it start acting this way? Were you using it, or did you just turn it on one day and it came on full speed?
-- Unix programmers never die; they just > /dev/null
View Woodknack's profile
Woodknack
11482 posts in 2347 days
#2 posted 04-12-2016 04:40 AM
Say more words.
- HapHazzard
Best response ever.
gpryon
#3 posted 04-12-2016 12:46 PM
- HapHazzard
I’ve had the comet II for a little over a year with no problems. I was turning an 8” bowl with the speed at about 1/4 of the medium range when it went to full speed on it’s own. The knob turns but the motor doesn’t change speed. Changed the belt to the high range and it had no effect. I’m in contact with Nova and waiting to see what they say.
-- gpryon
HapHazzard
#4 posted 04-13-2016 02:45 AM
It sounds like something in the motor controller shorted—possibly due to a power surge or overheating. I looked all over the teknatool and novatoolsusa websites, but couldn’t find any replacement parts related to that. If it’s still covered by the warranty, I’d hope they’ll replace or repair it. If not, your best bet would be to find an electronics technician who can troubleshoot it. Shorted components aren’t hard to find, but sometimes locating replacements can be challenging.
Woodknack
#5 posted 04-13-2016 03:56 AM
I bought a used Comet II, the previous owner complained that it would shut down after several hours of turning. I haven’t had that problem but the first thing I did was remove the control box, open it, and clean it out. The thing was packed full of dust and wood chips. My point being that the vents are easily clogged and could lead to overheating. Might be too late for yours, if that was the problem, but you might try cleaning.
gpryon
#6 posted 04-13-2016 05:27 PM
I bought a used Comet II, the previous owner complained that it would shut down after several hours of turning. I haven t had that problem but the first thing I did was remove the control box, open it, and clean it out. The thing was packed full of dust and wood chips. My point being that the vents are easily clogged and could lead to overheating. Might be too late for yours, if that was the problem, but you might try cleaning.
- Rick M.
Just got word from Teknatool that they are replacing the motor and control assembly under warranty. I will check the control assembly when I replace it. If it is full of dust and wood chips, I will start a better cleaning routine after installing the new motor and controller.
-- gpryon
Woodknack
#7 posted 04-13-2016 08:00 PM
Did you call or email? I emailed Teknatool and never heard back. Guess I need to call.
gpryon
#8 posted 04-13-2016 08:52 PM
- Rick M.
I emailed them off their website. Craig Walls worked with me.
-- gpryon
