Templates
Forum topic by zipmac22 posted 04-11-2016 01:53 AM 725 views 0 times favorited 8 replies Add to Favorites Watch
View zipmac22's profile
zipmac22
19 posts in 723 days
04-11-2016 01:53 AM
Hi, I’m looking at making some templates, but not sure what would be best to use. What do you use when you make a template?
8 replies so far
View kdc68's profile
kdc68
2635 posts in 2146 days
#1 posted 04-11-2016 01:55 AM
1/4” hardboard
-- Measure "at least" twice and cut once
View JBrow's profile
JBrow
1308 posts in 790 days
#2 posted 04-11-2016 02:06 AM
zipmac22,
I have made templates from plywood and MDF. Both work well, though I have come to prefer MDF because it is always flat. Using ¾” thick material is less of a headache when using a bottom bearing flush trim bit in a router and the template mounted below the work piece. With a pattern bit whose bearing is on top of the bit and the template mounted on top of the workpiece, thickness of the template is probably less of a concern and I would think ¼” hardboard could be used in this case. Bear in mind my experience is with templates used for just a few work pieces. Templates repeatedly used in a production should probably be of a tougher material than hardboard or MDF and maybe even plywood.
MrUnix
6185 posts in 2068 days
#3 posted 04-11-2016 02:34 AM
Tempered hardboard, plywood, MDF, HDPE, plexiglass… thickness and material depends on what the template is going to be used for (and how) as well as how often it will be used.
View jumbojack's profile
jumbojack
1673 posts in 2494 days
#4 posted 04-11-2016 02:49 AM
1/4” MDF. I like MDF because you can sand it to perfection. That said I will wear out if you use it repeatedly. I was making serving trays, lots of them and noticed in the crook of the template it was starting to wear away. I used the original to make a new one and then quit making serving trays
View iminmyshop's profile
iminmyshop
284 posts in 1863 days
#5 posted 04-11-2016 04:25 AM
I agree with the comment above about it depending on how often I’ll use it. MDF is excellent as it is flat and easily made to be whatever shape you want with perfection. BUT, it is also easily dinged and then you will be reproducing that ding perfectly unless it is repaired with some kind of filler (car body filler works well but the smell is nasty). So for frequently used templates I like a good grade of plywood.
-- http://www.alansfinewoodworking.com/
View newwoodbutcher's profile
newwoodbutcher
720 posts in 2720 days
#6 posted 04-11-2016 04:30 AM
1/2” MDF
-- Ken
View Picken5's profile
Picken5
250 posts in 2561 days
#7 posted 04-11-2016 04:34 AM
1/4” or 1/2” MDF, depending on what I have available at the moment, but I do prefer 1/2”.
-- Howard - "Time spent making sawdust is not deducted from one's lifetime." - old Scottish proverb
View devann's profile
devann
2246 posts in 2562 days
#8 posted 04-11-2016 06:15 AM
I agree with what Brad said. Another material I like to have around for templates is laminate flooring. It all depends on what size your template needs to be.
