[Chicagoland] Porter Cable 6 Gallon Air Compressor C2002 *AS IS*
Forum topic by Matt Przybylski posted 04-10-2016 10:28 PM 564 views 0 times favorited 0 replies Add to Favorites Watch
View Matt Przybylski's profile
Matt Przybylski
554 posts in 2464 days
04-10-2016 10:28 PM
I’m selling my Porter Cable 150 PSI 6 gallon air compressor. The unit is in working order however the tank pressure goes all the way up to 150 PSI and it tries to keep going at which point the safety valve opens and drops it back down to about 60 PSI and starts the process all over again. I’ve been using it by just not allowing it to reach 150 PSI before actual use but obviously that is not ideal.
I’m not sure what it would take to fix this but the parts are all readily available as this is an extremely common compressor and don’t cost an arm and a leg. You could also use it for parts if you need them for another compressor.
I’ve moved on to a different compressor so I have no interest in fixing this one. The compressor is located in Streamwood and I’m asking $30.
-- Matt, Arizona, http://www.reintroducing.com
0 replies so far
