Sanding Spoons
Forum topic by jcdyed posted 03-18-2010 03:56 AM 8809 views 0 times favorited 10 replies Add to Favorites Watch
View jcdyed's profile
jcdyed
9 posts in 2946 days
03-18-2010 03:56 AM
Topic tags/keywords: sand sanding spoon carving bowl tip question trick sander
I am starting to make some spoons, some from fallen trees and some from lumber scraps. I am wondering if anyone can think of a way to sand the inside of the bowl of the spoon. I would rather not pay $50 for an inflatable drum sander, and I cannot find any flexible disc sanders (for a drill) that are small enough.
Any ideas would be helpful.
Thanks
John
10 replies so far
View DragonLady's profile
DragonLady
298 posts in 2912 days
#1 posted 03-18-2010 04:03 AM
Hand sanding! not what you wanted to hear, probably…
-- A woman's work is never done-but power tools help!
View oluf's profile
oluf
260 posts in 2944 days
#2 posted 03-18-2010 04:29 AM
Chuck up a 3/8” drill in your drill. Wrap some old cloth near the end to form a ball. Wrap large pieces of sand paper around the ball and tie the ends like a Tootsie Roll. Change paper for finer grits or make up additional sanding drill bits.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
jcdyed
#3 posted 03-18-2010 06:00 AM
Dragonlady—for most of the sanding, I don’t mind hand sanding, but it is hard to get sandpaper into the bowl to sand. I have used foam sanding pads, but wondered if something better is out there.
Also I am carving using a Kutzall power carving bit, so the bowl of the spoon is a bit rough (especially on the green wood) Hand sanding the grooves and rough spots out is a pain. I rigged up my own rig from a rubber stopper (drilled through it and put a 3/16 bolt through it, and cut circles out of self adhesive sandpaper. Problem was the sandpaper discs would not last very long (using about 4 per spoon bowl). This set up worked, but not very efficient.
oluf—I am not sure I get what you mean. I guess you mean a dowel into a drill, but I am not sure about wrapping pieces of sandpaper around the ball, (should the tootsie roll be vertical or horizontal)?
View EricRFP's profile
EricRFP
106 posts in 2998 days
#4 posted 03-18-2010 06:45 AM
A little off topic but if you are using fallen trees, are you drying the wood first? For the most part, fallen trees do not dry, they rot, crack and rot before they ever dry correctly. Just a though.
-- Eric, NorCal www.rocklinforestproducts.com
jcdyed
#5 posted 03-18-2010 06:55 AM
EricRFP—I am splitting some and letting them dry, others I get to a rough cut shape and let dry.
View Pete Mohr's profile
Pete Mohr
75 posts in 2993 days
#6 posted 03-18-2010 01:48 PM
I use a scraper. You can buy curved scrapers or make your own. I used an old saw blade to make some. Just cut/grind it to the shape you need. Sharpen it and scrape away.
pete
-- "Man is so made that he can only find relaxation from one kind of labor by taking up another." -Anatole France
View Yekrub's profile
Yekrub
47 posts in 2905 days
#7 posted 03-18-2010 03:21 PM
I attached a retangular piece of medium density sponge or foam to an old drill bit (a long bolt works as well) with double side tape or glue. I then attached a square piece of the sanding papers to the end of the sponge with glue. Double sided tape works too but make sure it sticks. You do not want this flying off at high revolutions. I then stick the bit (or bolt) into my drill. The sponge allows the sand paper to flex. Depending on the size of the spoon’s bowl you can increase the size of the retangle of sponge.
Edit: After reading what I had wrote, its kind of hard to understand. Here is a video that shows almost exactly what I have used.
http://www.youtube.com/watch?v=OfUSgVwbo2U
The addition of a rubber band to hold the sponge onto the bolt or drill bit is a way better idea.
View richgreer's profile
richgreer
4541 posts in 2979 days
#8 posted 03-18-2010 03:34 PM
You can rough out the spoon with a dremel and a rasp type attachment and finish with sand paper.
View woodcrafter47's profile
woodcrafter47
352 posts in 3010 days
#9 posted 03-18-2010 04:01 PM
I too use a dremel with rasp and little drum sanders,then finger sand.
-- In His service ,Richard
jcdyed
#10 posted 03-18-2010 11:33 PM
Thanks for all the responces. I have a question for those that hand sand.
Do you just use sandpaper or do you use something to hold the sandpaper (small curved block, foam, dowel, etc…)?
