Air Handler Motors
Forum topic by SuperCubber posted 04-09-2016 03:43 PM 841 views 0 times favorited 16 replies Add to Favorites Watch
View SuperCubber's profile
SuperCubber
1015 posts in 2186 days
04-09-2016 03:43 PM
I’m planning on making a shop air filter from an old blower motor and fan. I’m curious as to the motor’s use for anything else. I have a more-or-less endless supply of the motors for the cost of shipping. Can I use them for anything else?
Thanks,
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
16 replies so far
View jkinoh's profile
jkinoh
95 posts in 1799 days
#1 posted 04-09-2016 03:59 PM
Are you talking furnace squirrel cage type blower, or something smaller?
-- Why buy it for $300 when you can make it for $500!!
View jonmakesthings's profile
jonmakesthings
73 posts in 720 days
#2 posted 04-09-2016 04:18 PM
I’ve been wanting to make an air filtration system the exact same way, I have access to all the air handler blowers I want. Haven’t got around to it yet.
-- How can you have any pudding if you don't eat your meat?
SuperCubber
#3 posted 04-09-2016 04:23 PM
- jkinoh
Yeah, squirrel cage blower. Anything from 1/6 to 1/2hp motors.
jkinoh
#4 posted 04-09-2016 04:37 PM
I have a couple that I was considering the same thing. They’re both 1/3hp….I think. I use one just to circulate air in the shop in the summer. My concern was too much cfm. I have set to high speed, so maybe low speed would be better? I don’t think you want a lot of air blowing through the filter (or getting sucked through the filter).
View crank49's profile
crank49
4029 posts in 2873 days
#5 posted 04-09-2016 05:25 PM
It is possible these motors are rated for air handling only. Specifically the air they handle is required to keep the motor cool. In a non-air handling application the motor would overheat.
View 01ntrain's profile
01ntrain
237 posts in 972 days
#6 posted 04-09-2016 06:08 PM
- crank49
I think you’re over-thinking it. In the context of the OP’s post he is essentially talking about making his own “air handler” I’ve got a dedicated air filtration unit made by Wen. It’s a dual squirrel cage that pulls air in thru a set of filters and blows it out. Pretty much what an air-handler does on a furnace minus the duct-work. No talk about motors rated for this work in the manual…..
As far as the other question about speed….the Wen has 3 speed settings. A blower motor should have multi-taps to control the speed. If you can harness them all with a 3-position switch you should be able to dial in the speed that is best for your needs. Honestly, I use all 3 with mine.
View bigblockyeti's profile
bigblockyeti
4981 posts in 1622 days
#7 posted 04-09-2016 06:15 PM
That should work out pretty well, especially with the newer blower motors, efficiency and little noise are paramount objectives in the design. A box containing one with a few good air filters surrounding it should work great.
View MrUnix's profile
MrUnix
6325 posts in 2101 days
#8 posted 04-09-2016 06:23 PM
I think you re over-thinking it. In the context of the OP’s post he is essentially talking about making his own “air handler”
- 01ntrain
Nope, the question was:
In which case, Crank was correct – that they may not be appropriate for anything other than an application which moves air over the motor for cooling. If it is that type of motor, it can still be used, but an external fan or other cooling method would need to be employed to prevent overheating.
SuperCubber
#9 posted 04-09-2016 07:18 PM
Thanks for the replies. Crank and Brad nailed it. I’ll use one for the air filter and maybe a second air filter.
View DIYaholic's profile
DIYaholic
19535 posts in 2577 days
#10 posted 04-09-2016 11:50 PM
I believe that others have used them for a downdraft sanding table….
SuperCubber
#11 posted 04-10-2016 12:46 AM
Hmm… That sounds like an interesting idea.
View ScottStewart's profile
ScottStewart
119 posts in 2034 days
#12 posted 04-10-2016 12:45 PM
I would like to do this as well, but I can never find the squirrel cage blower, where do you guys get them?
SuperCubber
#13 posted 04-11-2016 01:52 AM
My cousin owns an AC business, but he said he recycles them when he takes out old ones, so you can probably pick them up cheap from an AC repair company.
jkinoh
#14 posted 04-11-2016 12:45 PM
A friend made a downdraft out of a squirrel cage blower. Works well, but lots more volume to move.
This is either a coincidence, or Grizzly is watching me! (I don’t save cookies or browser history). Anyway, I’m posting and viewing comments on this thread and get an email from Grizzly for the following:
DIYaholic
#15 posted 04-11-2016 12:48 PM
That right there…. is a deal to jump on!!!
I got that Grizzly Air Filter, for that same price….
If funds weren’t so tight, I’d get another!!!
