sketchup compound miter
Forum topic by mikeho posted 03-17-2010 04:45 AM 3568 views 0 times favorited 8 replies Add to Favorites Watch
View mikeho's profile
mikeho
52 posts in 3119 days
03-17-2010 04:45 AM
Trying to design a compound miter on the end of a 2×4 with sketchup. If I angle the board 10 degrees and cut the end of the board at 10 degrees then turn it 90 degrees the next cut (14 degrees) will angle into the board. hope this makes some sense.
-- Mike, Thedford NE
8 replies so far
View tooldad's profile
tooldad
660 posts in 3712 days
#1 posted 03-17-2010 05:10 AM
sounds a bit risky to be making those cuts. will require jigs for safe and accurate cuts
View davidpettinger's profile
davidpettinger
661 posts in 3197 days
#2 posted 03-17-2010 04:32 PM
Huh?
-- Methods are many,Principles are few.Methods change often,Principles never do.
View PurpLev's profile
PurpLev
8535 posts in 3645 days
#3 posted 03-17-2010 04:57 PM
you mean something like this? :
mikeho
#4 posted 03-17-2010 05:14 PM
You got it purplelev——-now how did you do it?
View GFYS's profile
GFYS
711 posts in 3468 days
#5 posted 03-17-2010 05:37 PM
use the protractor tool. About the only thing easier than cutting this on a compound miter saw is drawing it in sketchup.
PurpLev
#6 posted 03-17-2010 05:57 PM
I started with a 2×4, used the protractor tool, and made a guideline from one corner at a 10 degree angle:
I then selected the opposite EDGE of the ‘board’ and using the MOVE tool, moved it down (select move tool, click on the edge, then press on the UP arrow key on the keyboard to lock the move to only the up-down (blue) direction) to the guideline:
I then created the compound angle on the other face of the 2×4, at 10 degrees:
And selected the adjacent EDGE to the one I moved earlier, and MOVED this new EDGE down to the NEW guideline:
All done!
Since this is a component, you can see the original 2×4 bounding box with the newly created compound ‘cut’ end:
mikeho
#7 posted 03-17-2010 06:15 PM
cool I figured it was easy just couldn’t figure it out. I was trying to use the pencil tool. Thanks a bunch!
PurpLev
#8 posted 03-17-2010 06:19 PM
no problems. from my experience, the move tool is the most neglected tool in the bunch, but can do some things that are otherwise almost impossible and in a very simple way.
