bringing out an etching on a old saw blade
« back to Hand Tools forum
Forum topic by darylkoehn posted 04-07-2016 01:47 PM 938 views 0 times favorited 4 replies Add to Favorites Watch
View darylkoehn's profile
darylkoehn
1 post in 747 days
04-07-2016 01:47 PM
I was wondering how to clean an old saw blade, to bring out the etching that’s on it, without doing damage to the etching.
Thank you.
View Woodknack's profile
Woodknack
11482 posts in 2347 days
#1 posted 04-07-2016 04:39 PM
ferric chloride
View bandit571's profile
bandit571
19743 posts in 2650 days
#2 posted 04-07-2016 04:48 PM
There is a “Gun Blue Paste” sold at sporting goods stores. Spread it on, allow to dry, use a sanding block to sand off the higher areas around the etch.
View Johnny7's profile
Johnny7
361 posts in 1058 days
#3 posted 04-07-2016 07:33 PM
Here’s the answer your question leads me to believe you were actually looking for:
1. use a single edge razor blade, held at a relatively low angle, to “shave” rust, crud from plate.
2. use wet-or-dry paper, lubed with mineral spirits, or WD-40 (some even use Simple Green) wrapped around a block of wood to lightly sand the are you suspect holds an etch.
start with 360 or 400 grit—if necessary, go coarser, 200 or even 180. The block prevents uneven finger pressure which can obliterate the etch in no time.
don’t over do it!—etches, as opposed to stamped makers’ marks—are not deep.
View Don W's profile
Don W
18686 posts in 2535 days
#4 posted 04-07-2016 11:01 PM
