Forstner bit set
Forum topic by willhime posted 04-07-2016 05:53 AM 1247 views 1 time favorited 14 replies Add to Favorites Watch
View willhime's profile
willhime
128 posts in 1780 days
04-07-2016 05:53 AM
Topic tags/keywords: resource tip question drill press drill-driver blade
I need specifically a 1.5” forstner bit (for making a router table plate hole). I figured I might as well just indulge the idea of getting a full set (16-31 piece). For over 2 years, I’ve had an 8-bit porter cable set I bought at Lowe’s for $30. Despite the sexy appeal of a huge MLCS/Grizzly/Rockler, etc, they still drill pretty good. I’ve dropped them, accidentally gone into an embedded screw, burned some, and they keep ticking. There have been many times though where I’ve needed the 1 1/8, or a 2” or whatever which has me still on this hunt. Are the larger sets worth it ? I know this is a pedestrian question, but I’ve never used any other brands.
-- Burn your fire for no witness
14 replies so far
View teejk02's profile
teejk02
489 posts in 1366 days
#1 posted 04-07-2016 02:19 PM
Would have to wonder how often you would use the larger ones. I have a cheap set from Menards that goes up to 1” and they work just fine but I don’t use any of them often. Anyway, you might check any outfit that sells European style “cup” hinges. CShardware might be a good start.
View ChrisK's profile
ChrisK
2017 posts in 3322 days
#2 posted 04-07-2016 02:30 PM
I have 3 sets to go from 1/4 to 2-1/8 by 1/16” and 2-14 to 3-1/8 from Peachtree Woodworking.
I use them all the time for fixtures, templates, and finished parts. I think I have used just about every size over the last few years.
http://ptreeusa.com/forstner_bit_sets.htm
I got the sets when they were on sale.
-- Chris K
View Ocelot's profile
Ocelot
2127 posts in 2879 days
#3 posted 04-07-2016 03:21 PM
I have a harbor freight set on 1/8ths from 1/4 up to 2” that has been perfectly adequate for my needs. It’s not like I drill 100’s of 1 7/8 holes, but if I ever need one, I’ve got it.
I think it’s this one http://www.harborfreight.com/16-piece-titanium-nitride-coated-forstner-bit-set-39812.html
Mine may be 1/2 shank version. I can’t remember.
You can almost always find a 20% off coupon which would bring it down to around $30 plus tax.
Probably if you buy a set, you’ll never need another.
Grizzly has some relatively inexpensive carbide sets and I’ve been tempted to buy the 1/16ths filler set which goes between my 1/8ths set. I’ve been tempted but have no pressing need for it, so haven’t bought.
-Paul
View Woodknack's profile
Woodknack
12469 posts in 2621 days
#4 posted 04-07-2016 04:30 PM
I own the Porter Cable set, 14 bits for $40. I used to own some old forstner bits that were razor sharp but clogged like crazy. The PC set doesn’t clog but are not razor sharp. They cut clean enough holes and are adequate for my purposes. The case is blown molded plastic and is adequate. I can’t brag about them but I don’t dislike them.
View bluethundra's profile
bluethundra
27 posts in 1057 days
#5 posted 04-07-2016 05:47 PM
I own the Porter Cable set, 14 bits for $40. I used to own some old forstner bits that were razor sharp but clogged like crazy. The PC set doesn t clog but are not razor sharp. They cut clean enough holes and are adequate for my purposes. The case is blown molded plastic and is adequate. I can t brag about them but I don t dislike them.
- Rick M.
I also own this set and have no complaints
View oldnovice's profile
oldnovice
7380 posts in 3608 days
#6 posted 04-07-2016 05:53 PM
I bought a set of Mastergrip model #480082 at Costco, 1/4” to 2-1/8” in 1/4” increments (16 pieces) less than $40 and not a bad set as they are “guaranteed for life”, whatever that means ….. but they did include a phone number for service. No indication of country of origin.
I am very satisfied with the performance of this set.
View HokieKen's profile
HokieKen
7627 posts in 1379 days
#7 posted 04-07-2016 06:53 PM
I have a harbor freight set on 1/8ths from 1/4 up to 2” that has been perfectly adequate for my needs. It s not like I drill 100 s of 1 7/8 holes, but if I ever need one, I ve got it.
I think it s this one http://www.harborfreight.com/16-piece-titanium-nitride-coated-forstner-bit-set-39812.html
Mine may be 1/2 shank version. I can t remember.
Probably if you buy a set, you ll never need another.
Grizzly has some relatively inexpensive carbide sets and I ve been tempted to buy the 1/16ths filler set which goes between my 1/8ths set. I ve been tempted but have no pressing need for it, so haven t bought.
-Paul
- Ocelot
I’ve got the same set and they have served me well. I don’t use the large ones that often but I use the ones <1 inch quite a bit and they seem to hold their edge well.
-- Kenny, SW VA, Go Hokies!!!
View cdarney's profile
cdarney
104 posts in 3271 days
#8 posted 04-07-2016 07:29 PM
I tend not to buy large sets of bits…except drill bits. Router bits, router profile bits and forstner bits I normally buy one of maybe two at a time. I have no idea when I would use some of the bits in the larger sets and having them would be something of a waste.
I generally go to MLCS for bits. They ship fast and free. I live reasonably close to them and have gotten my order the next day several times.
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/forstinx.html
View Monte Pittman's profile
Monte Pittman
30153 posts in 2579 days
#9 posted 04-07-2016 07:46 PM
I have Forstner bits up to 3-1/2”. I use them a lot and love them.
Woodknack
#10 posted 04-07-2016 07:54 PM
The thing about drill bits is I hate not having the size I need, having to stop working and go to the store or wait a few days for mail order. It’s worth an inexpensive set just for that reason alone.
View MadMark's profile
MadMark
979 posts in 1694 days
#11 posted 04-07-2016 08:21 PM
Been buying grizzly.com Roman Carbide (China) forstner bits ‘as needed’. Now I have full set 1/4” to 1” by 1/8” plus a 35mm for cabinet hinges and both 3” & 2-3/4” for a special job. I only buy carbide, HSS is worthless.
M
oldnovice
#12 posted 04-08-2016 04:46 AM
Correction, they were 1/8” increments and I bought these a number of years ago!
HokieKen
#13 posted 04-08-2016 09:49 AM
Been buying grizzly.com Roman Carbide (China) forstner bits as needed . Now I have full set 1/4” to 1” by 1/8” plus a 35mm for cabinet hinges and both 3” & 2-3/4” for a special job. I only buy carbide, HSS is worthless.
M
- MadMark
If it’s a production environment, sure. But for occasional use in wood HSS is fine. Even for metal work machine shops use HSS for all but the most used sizes with anything softer than carbon steel.
View rick1955's profile
rick1955
264 posts in 1672 days
#14 posted 04-08-2016 09:21 PM
No one mentioned multi-spur bits or saw tooth forstner bits from Lee Valley. People confuse carbon steel with High Speed Steel. We drilled hundreds of hole with these bits. I’ve dealt with tooling for over 50 years.
-- Working smarter with less tools is a true crafts person...
