luan plywood
Forum topic by Jim K posted 1160 days ago 4023 views 0 times favorited 5 replies Add to Favorites Watch
View Jim K's profile
Jim K
94 posts in 1303 days
1160 days ago
Help
I need some tips on cutting luan plywood without lots of chips?
Would it be helpful to turn the piece upside down I have the good side up?
Thanks Jim K.
5 replies so far
View mikedrums's profile
mikedrums
102 posts in 1202 days
#1 posted 1160 days ago
What are you using to cut it?
A Zero Clearance Insert would be helpful on the table saw.
If you’re using a hand held circular saw, you can make a ZCI by carpet taping (or screwing) a piece of hardboard or mdf to the bottom of the saw.
Also, a good masking tape can work, depending on the Uglan… I mean, Luan.
View RockyTopScott's profile
RockyTopScott
664 posts in 1644 days
#2 posted 1160 days ago
Score it first
-- “Socialism in general has a record of failure so blatant that only an intellectual could ignore or evade it” ― Thomas Sowell, The Thomas Sowell Reader
View Abbott's profile
Abbott
2570 posts in 1469 days
#3 posted 1160 days ago
Yes, it would be helpful to turn it upside down.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
View Michael Murphy's profile
Michael Murphy
448 posts in 1171 days
#4 posted 1160 days ago
How thick?
Unless you have a blade with Negative hook, and maybe even if you do, take a light scoring cut first, like the blade 1/32”- 1/16” into the material, then raise the blade up and make a second cut through at the same fence setting with the blade about an eighth to quarter inch above the top surface of the material.
Luan is pretty chippy no matter what.
-- Michael Murphy, Woodland, CA.
View Mike's profile
Mike
89 posts in 1330 days
#5 posted 1159 days ago
I used to work at a door shop and we where always cutting luan doors and skins. For cutting across the grain we scored them with a utility knife and put some cheap masking tape over the score mark befor running thru the table saw or a strait edge with a skill saw.
-- Mike, Cantral Oregon
