V-Drum type or Thickness sander?
Forum topic by BrianA posted 04-06-2016 08:37 PM 614 views 0 times favorited 4 replies Add to Favorites Watch
View BrianA's profile
BrianA
76 posts in 2995 days
04-06-2016 08:37 PM
A few years ago I built a sand flea type V drum sander. Works Well but I was wondering if I should have built a thickness sander instead. It does take a lot of passes over the top to get is smooth. It looks like it maybe easier and quicker to use the other style. Was wondering others opinion.
Thanks
Brian
View Jim Finn's profile
Jim Finn
2647 posts in 2887 days
#1 posted 04-07-2016 01:42 AM
I have had both. Both are very slow to get something sanded smooth. I still have the “V” sander but the drum sander I had died. I really do not miss it.
-- Website is https://craftingcouple.com/
View ArtMann's profile
ArtMann
936 posts in 781 days
#2 posted 04-07-2016 01:48 AM
I have both. I use the 24 inch V drum sander I built with 120 grit after I do thickness sanding with 80 grit. The V drum sander is low power and has no way of regulating the uniformity of thickness but it works quite well as an intermediate or finish sander for broad surfaces.
Edit: My drum sander is a commercial unit. I would not attempt to build a thickness sander because I need more power and ruggedness than a home made unit can provide.
View Gene Howe's profile
Gene Howe
10354 posts in 3394 days
#3 posted 04-07-2016 03:32 PM
My 24” “V” sander is used to flatten pieces for building thick blocks that will become band saw boxes.
Like Jim, I had a drum sander once. Mine was an open end type and I hated it. VERY hard to align and keep aligned. I sold it and good riddance.
BrianA
#4 posted 04-07-2016 11:29 PM
Well Looks like opinion is heading toward not ripping apart the V drum and making a thickness sander?
Brian
