Frame and Panel joints
Forum topic by JimmyNate posted 03-15-2010 07:24 PM 1303 views 0 times favorited 3 replies Add to Favorites Watch
View JimmyNate's profile
JimmyNate
124 posts in 3254 days
03-15-2010 07:24 PM
Topic tags/keywords: joint frame and panel tenon stub tenon biscuit dowel rail stile
When is a stub tenon not enough? Is there such a time?
I’m making a frame and panel bookcase. I’ve dry fit the panel for a side and there is just a little slop in the fit. I can clamp it square without much fuss, but should I strengthen the rail to stile joints?
I’m considering recutting the rails, mortising the stiles and extending the stub tenons into a deeper 1” or 1 1/2” tenon.
I’m considering adding a biscuit once the frame is clamped and flush cutting it.
I’m considering dowelling the joints.
What do ya’ll think?
-- "We are what we repeatedly do; excellence then is not an act but a habit." ---Aristotle
3 replies so far
View Michael Murphy's profile
Michael Murphy
453 posts in 2909 days
#1 posted 03-16-2010 04:48 PM
You don’t describe how long the tenon is now. Assuming 3/8” deep groove for panel and the length of the tenon on the rail ends, that would be enough if the rail is 2” wide or so and you have a decent fit. In my opinion anyway.
-- Michael Murphy, Woodland, CA.
View sittingbuller's profile
sittingbuller
16 posts in 2903 days
#2 posted 03-16-2010 09:03 PM
You don’t want the joints too tight or you will have a problem gluing them up. a little looseness is good.
Joe
-- Requirements for woodworkers: Sharp mind, sharp wit, sharp tools.
JimmyNate
#3 posted 03-17-2010 05:03 PM
Thanks for the feedback Joe.
Michael, they are 3/8” grooves and 3/8” stub tenons right now. The rail and stile width is 2 3/4”. The stiles are 78” long. On the sides, the rails only span about 8 inches, but on the back, there will be 36” rails.
