what size hinges should i use?
Forum topic by Johnalan Thomas posted 04-05-2016 06:25 PM 552 views 0 times favorited 3 replies Add to Favorites Watch
View Johnalan Thomas's profile
Johnalan Thomas
50 posts in 824 days
04-05-2016 06:25 PM
Topic tags/keywords: hinge hinge size help cedar chisel finishing shaker
Hello, this is my second fine woodworking project and I’m making a blanket chest, what size hinges should I use for the lid, the lid is 23×17. I bought door hinges but I think that’s a little much and would take away from the bountiful eastern red cedar. any suggestions on the size, the red cedar is 3/4 btw
-- John Darlington Sc
3 replies so far
View brtech's profile
1027 posts in 2853 days
#1 posted 04-05-2016 06:33 PM
Simple answer = piano hinge
More complex answer: what is the probability that small kids will be anywhere near this? If it’s non-zero, then I would strongly urge you to use something that will avoid hurting little fingers. There are hinges that do this:
although you can use any kind of hinge plus some kind of lid support such as:
View Aj2's profile
1303 posts in 1728 days
#2 posted 04-05-2016 06:41 PM
I agree with Brtech.
-- Aj
View MadMark's profile
979 posts in 1383 days
#3 posted 04-05-2016 07:27 PM
Hinges are rated by their carrying load. If you get a hinge rated more than 2x the carry weight then if one hinge fails the 2nd will carry the load for a while.
Hinges should be evenly spaced so the load is balanced. For two hinges its 1/4 – 1/2 – 1/4.
-- Madmark -
