| Forum topic by Betsy | posted 1994 days ago | 565 views | 0 times favorited | 8 replies | ![]() |
1994 days ago |
Topic tags/keywords: plane iron I just sat down to work on my plane refurbishing job and noticed something about my plane iron. It rocks! It’s not musical so I’m pretty sure that’s not a good thing. Are plane irons supposed to be no rocking irons or once you place them back in the plane and use the cap iron and lever it gets straightened out. The rock is quite a lot. Thanks -- Like a bad penny, I keep coming back! |
8 replies so far
#1 posted 1994 days ago |
Plane irons should be lapped dead flat and shiny on the back, so that the arris is nice and clean when the iron is honed. I use a surface plate and abrasive sheets (scary sharp) to lap mine. -- The days are long and the years are short... |
#2 posted 1994 days ago |
Thanks Myron. There is no problem with getting the flat and shiny part—- but it rocks from one end to the other – kind of like a bowed piece of lumber. That can’t be right. Is this iron a lost cause or should I try to straighten it out. I’m not sure I’m explaining this well and there is not a good way to picture it. -- Like a bad penny, I keep coming back! |
#3 posted 1994 days ago |
End to end? That’s weird, but I don’t know how much it would matter. The frog should hold it at the correct angle for the cutting end. -- http://www.peteroxley.com -- http://north40studios.etsy.com -- |
#4 posted 1994 days ago |
Yep end to end. I was thinking I could put it into a vise and give it a couple of whacks with a dead blow hammer. But I may do more harm than good. I’d like to think that you are right and that once I put it back in the frog it should be ok. Sharp is what matters more I would hope. -- Like a bad penny, I keep coming back! |
#5 posted 1994 days ago |
arris |ˈaris| Great word, Myron. -- "Bordnerizing" perfectly good lumber for over a decade. |
#6 posted 1994 days ago |
On my Sargent, the iron was bent after it exits the back of the frog. Not sure if that was a feature of the original design, or some ham-handed modification by an owner. It had a fair curve and it still seems to work well as it seats in the frog without issues. -- "Bordnerizing" perfectly good lumber for over a decade. |
#7 posted 1994 days ago |
Shoot, I thought Myron just hit the wrong button on the keyboard!! Simple solution, when in doubt, buy a new iron. Even a Stanley. -- Thos. Angle, Jordan Valley, Oregon |
#8 posted 1994 days ago |
If the cap iron and lever cap straighten it out and lock it flat against the frog . . . don’t worry about it. -- Paul, Texas |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1523 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6149 |
