Can tenons be made on a 45 degrees?
Forum topic by Andrew Betschman posted 03-15-2010 12:48 AM 1243 views 0 times favorited 7 replies Add to Favorites Watch
View Andrew Betschman's profile
Andrew Betschman
309 posts in 3220 days
03-15-2010 12:48 AM
On the corner cabinet I’m making I need to made a base for it. So it can sit on a un-level floor. Can tenons be made on 45 degrees? So the mortises can be made square to the the piece it is mating.
-- Andrew, Ohio https://www.etsy.com/shop/AndrewBetschman
7 replies so far
View davidpettinger's profile
davidpettinger
661 posts in 3197 days
#1 posted 03-15-2010 02:00 AM
I’m sure it could be done. But the practicality of doing it is why it is not done. I’m trying to wrap my head around why you would want to try and do it. I can’t picture correctly what it is you want to do.
If you make a standard base for a cabinet, scribe the base to the floor to make it sit even. You can screw blocking to the floor and attach the base to the blocking. If you don’t mind, a little more information.
-- Methods are many,Principles are few.Methods change often,Principles never do.
Andrew Betschman
#2 posted 03-15-2010 02:36 AM
If you take a look at the Virginia Corner Cabinet I’m making. I need to make a base to take care of some un- level floors.
teenagewoodworker
2727 posts in 3765 days
#3 posted 03-15-2010 02:46 AM
angle your mortise. having a tenon that is angled at 45 degrees seriously compromised the strength of the tenon. since the grain is no longer running through the tenon and anchored in the board.
View bladeburner's profile
bladeburner
88 posts in 3084 days
#4 posted 03-15-2010 03:52 AM
No problem with a Woodrat, although as teenagerwwr points out, the shear strength is compromised.
View Moron's profile
Moron
5032 posts in 3890 days
#5 posted 03-15-2010 04:25 AM
isnt that where u put a leg ? or a “foot” ?......hidden or not,?
good question eh?
TopamaxSurvivor
18269 posts in 3673 days
#6 posted 03-15-2010 04:40 AM
Seems like dowels or floatiing tenon would be stronger.
View Eagle1's profile
Eagle1
2066 posts in 3061 days
#7 posted 03-15-2010 08:53 AM
I agree with topamax.
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
