6' Workbench top joinery
« back to Joinery forum
Forum topic by willing_to_learn posted 04-04-2016 04:10 PM 488 views 0 times favorited 1 reply Add to Favorites Watch
View willing_to_learn's profile
willing_to_learn
4 posts in 693 days
04-04-2016 04:10 PM
Hello everyone I’m new here and I am open to any advice you can give me on a workbench top.
My top will consist of 6 boards 6’ long and 4 3/4” wide. 1 1/2” thick pine. I have yet to decide on how I want to join the boards together. A few of the boards are warped a little, maybe 1/8” or a little more, not horrible. I don’t have a jointer but plan on purchasing a thickness planer in the next week or so. Is it worth planing them down to take the bow out just for a bench top? I like for it to be flat as possible. As for joining them together I was wondering how good pocket holes would be with glue. By no means will I attach the top after its all done using pocket holes. Another method would be just glue, clamps, and cauls. Or would splines be a good option? I know its not meant to be for strength but to keep it from sliding all over the place. This would also be good practice for another project. I don’t have a biscuit joiner but a router bit for making them and can it also be used for a slot cutter? The boards have already been ripped on both sides 4 3/4”
Any suggestions will be helpful.
I might be over analyzing it too much but its a habit when it comes to woodworking.
1 reply so far
View pintodeluxe's profile
pintodeluxe
5569 posts in 2722 days
#1 posted 04-04-2016 04:24 PM
Planing boards unfortunately won’t take the bow out of lumber. A jointer is the best tool for that.
Planers only make boards thinner and smooth.
Once you have them flat and milled to size, do a dry fitting with clamps and cauls. If everything looks good, glue two boards together at a time. Then run those three planks through the planer. Finally, glue the three planks together. This will limit the amount of sanding, and the smaller glueups are easier to manage.
