Battery Chargers on Timer - Good Idea?
Forum topic by Zuki posted 03-14-2010 02:30 PM 5974 views 0 times favorited 10 replies Add to Favorites Watch
View Zuki's profile
Zuki
1404 posts in 4072 days
03-14-2010 02:30 PM
Topic tags/keywords: zuki vampire
I have been doing some reading on electrical usage and came across vampire electricity usage . . . when seemingly innocent items plugged in will use a significant amount of energy ($$$$$$) over time.
I got to thinking about my battery chargers. they are always plugged in with a battery in them. Would it cause damage to the battery if I put the charger on a timer only allowing it to charge for 3 hours per day?
So it will always be plugged in, but only charging for a portion of the day . . . thereby saving $$$$$.
Thoughts?
-- BLOG - http://www.colorfulcanary.com/search/label/Zuki
10 replies so far
View EEngineer's profile
EEngineer
1102 posts in 3608 days
#1 posted 03-14-2010 06:00 PM
It is a very good idea… particularly on cheaper chargers like those typically used for power tools. Constantly charging the battery will decrease the lifetime. Where I work they used battery powered screwdrivers for a lot of electronic assembly. Battery replacement went way down when they simply made sure that the battery chargers were unplugged every night rather than continuously charging them throughout the night.
The more sophisticated batteries for electronic equipment have limiters built into the batteries or chargers to limit the charging current as the battery approaches full charge. This prolongs the battery life. However, there is still power used in the rectification and charging circuitry itself, which is wasted power.
View hairy's profile
hairy
2701 posts in 3527 days
#2 posted 03-14-2010 06:51 PM
I’m a big fan of a trickle charger. What they do is maintain a full charge, and do not overcharge a battery.
This one is on my motorcycle: http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=69981&group_ID=17835&store=snapon-store&dir=catalog
This one is on my standby generator. http://matcotools.com/Catalog/toolcatalog.jsp?cattype=T&cat=2500&page=1&#58391 Part # MC15
Most tool companies have one. Look for a “smart charger”.Both of these are good quality. in my situation it is cheaper than a new battery.
I’m not sure what you are trying to keep up, but I had one for several years on an antique truck that was driven infrequently. Small batteries, such as lawnmower, motorcycle etc. will quickly be ruined if left in a low charge state. The lead plates get clogged,sulfated, and then the battery won’t take a charge. Gel batteries eliminate this problem.
-- My reality check bounced...
View Zuki's profile
Zuki
#3 posted 03-14-2010 07:26 PM
Sorry . . . I have a Dewalt 18v and two 12v drills.
hairy
#4 posted 03-14-2010 07:53 PM
Wow! Where was I coming from? Maybe I answered a question you haven’t asked yet?
View Padre's profile
Padre
930 posts in 3484 days
#5 posted 03-14-2010 09:46 PM
Most modern day chargers are designed to go down to ‘trickle’ mode when the battery is full. Having said that, I think that 90% of them don’t work.
So I think it is an excellent idea to put your chargers on a timer.
-- Chip -----------http://www.penmanchip.com-----------------Micah 6:8
EEngineer
#6 posted 03-14-2010 10:49 PM
Yeah, lead-acid batteries do require a trickle charge for exactly the reason you mentioned: plate sulfation. However, gel-cells do not eliminate the problem. They are slower, but the plates do sulfate. What you pay for trickle charging is probably a lot less than a new battery.
NiCad batteries, common in rechargeable power tools up until just recently, do not require a trickle-charge to keep them functional. Continuously charging them can lead to a runaway effect that actually decreases the lifetime or even destroys them. As someone else mentioned, you can get so-called “smart” chargers that reduce the charging current on a fully-charged battery, but the ones you get with the tool itself are almost always “dumb”. I have 2 cordless screwdrivers in my garage that are on a timer – about 3 hours on out of 24. I find that’s enough to combat the self-discharge rate and they have lasted about 2 yrs now. I never got more than 6 mos out of batteries I charged continuously.
Lithium ion batteries, found in most electronics and becoming popular in power tools now, are a whole ‘nother story. For many reasons, related to catastrophic failures that result in fire or outright explosion not just a dead battery, most li-ion batteries include smart charging electronics right in the battery itself.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3707 days
#7 posted 04-13-2010 10:28 AM
A friend of mine used to do a lot of fire calls and she mentioned that a surprisingly large part of the fires she attended were probably caused by the battery chargers being left plugged in which then overheated, burned and caused a fire…ever since I have been unplugging my chargers and all those transformers that seem to breed like rats when you have electronic equipment around.
View tblank's profile
tblank
61 posts in 2965 days
#8 posted 04-13-2010 11:09 PM
Instead of a timer, what about wiring a switch to the charger’s outlets and you just flip the switch when you come in or leave. Put it next to the light switches.
View Roger's profile
Roger
21 posts in 3140 days
#9 posted 04-13-2010 11:41 PM
Marc Spagnuolo has a video showing a simple charger/driver shelf using a DowelMax for assembly. At the end of the video he mounts it on a wall, positions his drill-drivers on top with the battery chargers beneath, and plugs all the chargers into a timer. If it’s good for him,,,,,,,I’m just saying….............
-- Do like you always do,,,,,Get what you always get!!
View Zuki's profile
Zuki
#10 posted 04-14-2010 01:12 AM
Since my initial posting I picked up a couple of digital timers. I set it up to charge for 4 hours per day. It seem to be working fine. Yesterday evening I popped in a dead 18v and this evening it was fully charged.
