Q's about priming and painting
Forum topic by jesinfla posted 04-04-2016 02:10 PM 514 views 0 times favorited 6 replies Add to Favorites Watch
View jesinfla's profile
jesinfla
275 posts in 1258 days
04-04-2016 02:10 PM
Hello all,
A few questions if you will:
I’m making wall mounted display cases – they’re 19”w x 45”h x 4 1/2”d (I’ll post some pictures as I get closer to finishing them).
I’ve made 2 so far – 1 I used 5/8 MDF. This was my first and created it as sort of a template and trial and error process to see if I could even do it. The 2nd I used wood, nothing special – just some 5/8 plywood from HD.
So far the biggest obstacle I had to overcome was the door – I made it like a picture frame with a cut out on the inside for the glass which is another topic later…
They’re not 100% quality but decent for my first attempts at building anything besides jigs that I can actually display in my houses LOL.
So now the questions:
I’m spraying primer on both – is that the correct/preferred method of applying primer to bare wood?
Next question: I want to paint them Hi Gloss Black. Should I spray the paint or should I roll/brush it?
Thanks in advance for any and all help in advance – it’s much appreciated.
-- They said I could be anything... So I became Sarcastic! They also said making drawers is easy... I think they lied :(
View conifur's profile
conifur
955 posts in 1272 days
#1 posted 04-04-2016 03:55 PM
Either way, which ever is easiest for you. I think you would a smoother look with spraying.
View rwe2156's profile
rwe2156
3073 posts in 1601 days
#2 posted 04-04-2016 04:01 PM
You can also get good results sanding between coats.
You’ll definitely get a better finish with spraying (in some cases it can be too perfect and look like it was factory made)
jesinfla
#3 posted 04-04-2016 06:05 PM
Thx – I coubt anything I create will look “too perfect” lol but one can wish.
Yes, sanding between primer coats at the moment then between paint coats as well
Thanks for the responses
View TMGStudioFurniture's profile
TMGStudioFurniture
55 posts in 939 days
#4 posted 04-04-2016 09:17 PM
The main problem with a high gloss finish is that it will show every single imperfection in your build – it basically hightlights imperfections.
-- https://www.etsy.com/shop/TMGStudioFurniture
jesinfla
#5 posted 04-04-2016 10:14 PM
- TMGStudioFurniture
Ouch – thanks for the heads up :(
Well it may not get to be pretty, but hopefully it will be ok to hang on my wall
View kdc68's profile
kdc68
2688 posts in 2397 days
#6 posted 04-04-2016 11:28 PM
If you don’t like gloss black, then you can always spray satin over it. One coat will dull the sheen.
-- Measure "at least" twice and cut once
