The best way to make a template for stars on a flag
Forum topic by woodbrain posted 04-04-2016 01:32 AM 2327 views 0 times favorited 6 replies Add to Favorites Watch
View woodbrain's profile
woodbrain
21 posts in 1163 days
04-04-2016 01:32 AM
I finished this flag today. I’m planning on making a few more. They will be different sizes. They go together pretty quick with the exception of the stars. I used hard board (I think that’s what it’s called) to make a template, which I broke on the 48th star. It still worked.
My question is, what’s the best way to make the star template? Is there someplace i can send the dimensions and have a few different templates made?
Would it be better to make them out of steel? or is that getting way expensive?
Thanks in advance!
View ksSlim's profile
ksSlim
1276 posts in 2919 days
#1 posted 04-04-2016 11:39 AM
I use flashing metal for that kind of template.
Inexpensive, easily cut with tin snips.
-- Sawdust and shavings are therapeutic
View Tennessee's profile
Tennessee
2873 posts in 2543 days
#2 posted 04-04-2016 11:58 AM
Is it a router template, or just a template to draw the stars out on a flat board? If drawn, you can buy a template from a lot of hobby and art stores that has multiple sizes of stars in it, or as my wife showed me once, cookie cutters come in stars, in multiple sizes. Who knew?
View Ghidrah's profile
Ghidrah
667 posts in 1251 days
#3 posted 04-04-2016 03:13 PM
You might consider phenolic or some other UHMW poly then search out a local commercial cabinet, woodsmith or sheet metal fabricator shop with a CNC and have them mill whatever size you need
-- I meant to do that!
View Puzzleman's profile
Puzzleman
417 posts in 2973 days
#4 posted 04-04-2016 03:46 PM
My question is what size are the stars?
Might be easier to take a 2×2 and cut the dimensions of the star into the end of the board all the way down using a table saw. Just simple angled rips. Then slice off the stars using the table saw.
-- Jim Beachler, Chief Puzzler, http://www.hollowwoodworks.com
View Jim Finn's profile
Jim Finn
2658 posts in 2951 days
#5 posted 04-05-2016 01:47 AM
I make the patterns for the stars I inlay into box lids. using 1/8” Masonite. Cut them using my scroll saw.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View Albert's profile
Albert
509 posts in 3618 days
#6 posted 07-27-2017 06:46 PM
‘Star Template’ search on Amazon.com if you are still interested in a source
