Delta fence itself is not square -- 36-725, 10" table saw, any fixes?
Forum topic by huyz posted 04-03-2016 10:17 PM 6569 views 0 times favorited 22 replies Add to Favorites Watch
View huyz's profile
huyz
58 posts in 855 days
04-03-2016 10:17 PM
Topic tags/keywords: delta table saw 36 725 36-725 fence square question
Hey all,
I just exchanged a Delta 36-725 table saw because one of the miter slots was not milled properly.
Got a problem with the fence now—the fence itself is not square. I realize the tilt on it can be adjusted but it seems like the center of the fence is sucked in along the entire length on both sides. Possibly from the screws inside being overtightened from the factory.
Attached a pic to show what it looks like with a square on the cast iron top, up agains the locked-down fence.
I tried loosening the screws inside the fence to lessen the tension but it seems irreversible. Anyway just wondering if any other owners of this saw had this problem? I suppose as long as my workpiece is flat against the cast iron top and makes contact with the bottom of the fence it should not be a problem.
22 replies so far
View knotscott's profile
knotscott
8006 posts in 3369 days
#1 posted 04-03-2016 10:40 PM
You could always build some sort of auxiliary fence. Handy to have. You can add all kinds jigs to them too….sacrificial fence, tall fence, hold downs, etc. You could always have Delta replace it, an hope the next one is better.
View conifur's profile
conifur
955 posts in 1146 days
#2 posted 04-03-2016 10:42 PM
What difference will it make? If the wood is flat and a 90* edge it will only touch the fence at one point of contact, where the fence and table meet.
View ThomasChippendale's profile
ThomasChippendale
244 posts in 926 days
#3 posted 04-03-2016 11:08 PM
Thanks conifer for another bad advice.
The fence should be flat, my unisaw fence has the same behaviour but less pronounced, looking forward for solutions.
PJ
-- PJ
View Richard H's profile
Richard H
489 posts in 1674 days
#4 posted 04-03-2016 11:16 PM
Do you mean the fence is warped?
If so there isn’t a whole lot you can do about it except build a auxiliary fence like Knotscott suggested or try to get Delta to replace it. You can overcompensate one end of it to far the other way so that your fence is close the entire length with it swinging from out of square one way at one end to out of square the other way on the other end but a square fence is pretty important especially when working with tall pieces on edge so it’s probably not something you want to try to live with unless you can get it really close to square the entire length.
conifur
#5 posted 04-03-2016 11:53 PM
PJ
- ThomasChippendale
I t was not advice it is a fact, and if cutting a taller piece it will contact the other point at the top of the fence.
If you want a solution, call customer service at Delta, and dont whine here.
View Kazooman's profile
Kazooman
1005 posts in 1946 days
#6 posted 04-04-2016 12:08 AM
PJ
- ThomasChippendale
- conifur
Well, what about cutting a dado to length where the top edge of the dado is contacting the concave center of the fence and not the bottom or the top of that sorry curved fence?????
You have to be kidding me that a brand new saw with a fence that is cupped over its entire length is acceptable!
Back we go. Get a good one.
conifur
#7 posted 04-04-2016 12:36 AM
PJ
- ThomasChippendale
- conifur
- Kazooman
Set a mark on the board to be dadoed and adjust accordingly, and I think you mean a rabbit not a dadoe
View RibsBrisket4me's profile
RibsBrisket4me
1554 posts in 2499 days
#8 posted 04-04-2016 12:46 AM
Is there any way to shim the face of the fence on that model?
View jbay's profile (online now)
jbay
2271 posts in 893 days
#9 posted 04-04-2016 12:57 AM
I would take it back and exchange it if I wasn’t happy with it.
I don’t have one so I can’t tell for sure, but maybe you could pull the caps off the end and fill it with a board to push it back out.
View hotbyte's profile
hotbyte
991 posts in 2969 days
#10 posted 04-04-2016 01:04 AM
Is face on other side straight? If so, can you swap them?
View Woodknack's profile
Woodknack
11601 posts in 2374 days
#11 posted 04-04-2016 01:07 AM
Mine is cupped a bit too, been using it going on 20 years and it has never made a difference. But if it bothers you, take it back. Yours is a little worse than mine. You could also flatten it like the sole of a plane.
jbay
#12 posted 04-04-2016 01:12 AM
If your “bent” on keeping it you could also bondo it, flatten it, and add a pc of laminate to it, but it’s a lot of work compared to taking it back.
View Nubsnstubs's profile
Nubsnstubs
1286 posts in 1724 days
#13 posted 04-04-2016 03:48 AM
The way light plays tricks on eyes, I’ll bet that gap that some posters are comparing to the Grand Canyon is less than .005”. That’s not enough to waste time on.. . What is the material that you’ve got the square up against? ............... Jerry (in Tucson)
View jacquesr's profile
jacquesr
342 posts in 1417 days
#14 posted 04-04-2016 05:17 AM
Have the same saw. Same issue. They are all like that.
Not a major issue, except when you can rock the piece and screw the cut.
I removed both sides and put phenolic ply instead.
You can also use UHMW – but It might be not perfectly flat.
Knotscott suggestion (as always) is spot on.
View jeff's profile
jeff
1080 posts in 3459 days
#15 posted 04-04-2016 05:32 AM
Probably wouldn’t let it bother you.Knotscott offers good advice.From your pic it looks like top and bottom of the fence looks ok though.
-- Jeff,Tucson,Az.
