Capspray HVLP Turbine Lacquar and Primer
Forum topic by savbooks posted 03-14-2010 02:44 AM 1962 views 0 times favorited 2 replies Add to Favorites Watch
View savbooks's profile
savbooks
6 posts in 3154 days
03-14-2010 02:44 AM
I have a Capspray 3 Stage Turbine sprayer and I have been spraying Lacquar for about 3 years. I have started building more custom bookcases out of Plywood and was looking to set up one gun dedicated to spraying primer. I been using your basic store bought Kilz primer but it is much thicker that lacquar so I guess it would need to be thinned.
If anyone is using a Turbine sprayer with a siphon cup setup and you are working with primer than please pass your setup on. Any tips will help.
-- Savbooks
2 replies so far
View barryvabeach's profile
barryvabeach
159 posts in 3191 days
#1 posted 03-14-2010 02:24 PM
I don’t have that model, but most spray guns work best when the material is of a certain viscosity. See if you can find a cheap Ford #4, or any other viscosity cup ( the actual one doesn’t much matter) Then time the lacquer that sprays will, and dilute the primer to get a similar reading. If you have a different sized spray tip, you can try that.
View Al Killian's profile
Al Killian
273 posts in 3901 days
#2 posted 03-29-2010 12:11 AM
I use Mohawk tinted lacquers for primer. It works great and no fussing with different tips and thinners. I do however have a seperate gun for different materails. One for stains, one for primers and one for clear lacquer. I thin mine 10% and it works fine with my CH 3 stage turbine.
-- Owner of custom millwork shop
