Question- Table top developed a check
Forum topic by Chelios posted 03-13-2010 11:01 PM 757 views 0 times favorited 4 replies Add to Favorites Watch
View Chelios's profile
Chelios
568 posts in 3033 days
03-13-2010 11:01 PM
Topic tags/keywords: question
It is not yet assembled. It is a 2 board lamination of 8/4 padauk. It developed a 12 inch hairline check starting at the end grain. The check is only visible from one of the sides. The boards have been in my garage/shop for 4 months and the check only developed in the last couple of weeks after I laminated them.
Is there anything to be done?
thanks
13600 posts in 3308 days
#1 posted 03-13-2010 11:12 PM
maybe clamp it with glue ,
and put some of those
Nakashima butterfly’s across it .
Chelios
#2 posted 03-13-2010 11:26 PM
Thanks Patron
I think I have seen those butterflies on some projects around here but I am not really familiar with how those are done. How does one do those? Chisel out the butterfly mortise and glue in the butterfly?
#3 posted 03-14-2010 01:38 AM
that is probably your best bet ,
as you don’t have the stuff to do it with a router .
you can however make the butterflies on the band saw or copping saw ,
and use the router to freehand the rough space for it ,
just stay 1/8” away from the edges ,
and finish with the chisel .
it will leave you a flat bottom to work to .
just leave the clamps on until the butterflies are dry ,
so the top doesn’t split again from the pounding .
Chelios
#4 posted 03-14-2010 04:47 AM
Thanks David!
I will go for it. Best
