Crown Molding-ceiling alignment
Forum topic by balsabob posted 1998 days ago 783 views 0 times favorited 2 replies Add to Favorites Watch
View balsabob's profile
balsabob
4 posts in 2111 days
1998 days ago
Topic tags/keywords: crown molding
My sister is having an installer put in some prefabricated cabinets for her kitchen and the crown molding running along the top of the cabinets do not meet the ceiling in the center. There is a small gap of approximately 1/4” in the center and is flush on both ends of the molding. I don’t have a picture which would help in explaining the problem. I was going to suggest that the installer use a block plane and remove some material from the top of both ends of the molding.
Any suggestions?
-- Bob, Calif.
2 replies so far
View miles125's profile
miles125
2177 posts in 2175 days
#1 posted 1998 days ago
I agree with ebanista….find a happy medium to scribe off. Either that or put a really heavy trunk in the attic over that center area…LOL
-- "The way to make a small fortune in woodworking- start with a large one"
View mrtrim's profile
mrtrim
1696 posts in 2050 days
#2 posted 1998 days ago
im with ebanista as well . crown moulding is something i do a lot of and its pretty much taboo to scribe it to a ceiling if you do any id make it as little as possible. theres not any great fix that i know of for this problem unless you do have access to the cieling from above an attic or crawl space . i havent personally tried the heavy trunk idea lol but i have actually went into the attic and driven shims between the ceiling joists and the sheet rock and forced the sheetrock down a bit . if you have accsess let me know and ill give you some help on how to locate the exact spot you need do this
