drilling 4x4's???
« back to LumberJocks.com Site Feedback forum
Forum topic by GaryBuck posted 03-13-2010 02:17 AM 8452 views 0 times favorited 7 replies Add to Favorites Watch
View GaryBuck's profile
GaryBuck
268 posts in 3192 days
03-13-2010 02:17 AM
Topic tags/keywords: question
I’ve got some old used cca treated 4×4’s and I’m trying to drill holes in them for a project I’m doing. The trouble is these are as hard as rocks and I can’t seem to hardly put a hole in them before the bit is dull. I’ve even used some good expensive bits and they seem to go farther but I still can’t get a hole drilled through them. Any ideas or sugestions would be greatly appreciated. I’ve used my 1 inch hammer drill and my bench top drill press and its like cutting concrete with a butter knife. It isn’t worth the project if I have to resharpen or buy new bits every inch of drilling as I need to do about 60 holes just for the one project. Any ideas??? I know you L.J. members will have some clue to help me out. Thanks
Gary Buck
7 replies so far
View bobkberg's profile
bobkberg
439 posts in 3039 days
#1 posted 03-19-2010 09:45 PM
How big do the holes have to be?
Since you didn’t describe what the end product of all this is, I can only guess at possible solutions.
You might consider using a hole saw if it’s larger than 5/8” or so, to keep the actual wood cutting to a minimum – make sure you’ve got a dust collector running if you do though.
Or – even so, drill a series of small holes just inside the radius with “sacrificial” bits to keep it on the cheaper side
Have you tried carbide tipped masonry bits?
Or – to avoid throwing good money after bad – change the fastening approach to something like masonry screws that are self tapping.
Or – Just go buy some wood that doesn’t cause you all this grief.
-- Bob www.singularengineering.com - A sideline, not how I earn a living
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3551 days
#2 posted 03-19-2010 10:14 PM
Try some tungsten drills they work good and last a while.Are the drills you are using old and need sharpening?Alistair
bobkberg
#3 posted 03-19-2010 10:28 PM
Ok – This idea is WAAAAY out there, but I thought I’d suggest it anyway.
Try using a pressure washer on highest force – straight narrow stream of water to make the initial hole. Then use drill bits to clean it up.
I have NO IDEA if it will work or not, but I have seen pressure washers go through wood.
I actually got the idea from an old Paul Bunyan story.
View araldite's profile
araldite
188 posts in 3370 days
#4 posted 03-19-2010 10:37 PM
Make sure your not dulling the bits by excessive heat build up due to too high a drill speed or not keeping the flutes cleared.
-- Failure is the road to success if you learn to learn from your mistakes - Vince, Greenville, SC
View RedShirt013's profile
RedShirt013
219 posts in 3628 days
#5 posted 03-19-2010 10:43 PM
What kind of drill bit are you using? If the bit has poor chip extraction sawdust will just jam in the flutes, the bit won’t cut, and the high heat generated will dull the bits quick. If you haven’t yet try an auger bit and see if that helps.
-- Ed
View DaddyZ's profile
DaddyZ
2475 posts in 3006 days
#6 posted 03-19-2010 10:46 PM
Auger Bit & Hand Drill IMHO
View Deltawood's profile
Deltawood
40 posts in 3163 days
#7 posted 03-20-2010 12:00 AM
I agree with DaddyZ, an auger bit is designed for this purpose, they’re very aggressive. If you do use a electric drill, have a good grip and hold on.
-- - If it ain't broke, don't lend it!
