Help identifying an old plane
« back to Hand Tools forum
Forum topic by jkdavies posted 04-01-2016 03:23 AM 1232 views 0 times favorited 11 replies Add to Favorites Watch
View jkdavies's profile
jkdavies
5 posts in 696 days
04-01-2016 03:23 AM
Topic tags/keywords: question plane tool
Hey guys,
I’m completely new to hand planes, but the other day as I was looking for something else on our farm, I came across three old planes stuffed in a cubby hole that I’ve never seen before. After a little research, I’ve identified one of them as a Bluegrass Belknap 107-16 having the number 4 cast directly beneath that number, a good ole Stanley No. 4 type 19, and a third plane that is a No. 4 1/2 from the casting on the toe, but the only other casting on it is what looks like an “I S” cast vertically on the bed underneath the tote. I wouldn’t even have seen it if I hadn’t taken the handle off to clean it up. Some of the things on the frog put me in mind of the Stanley No. 4, but it’s design is a bit different. I am just curious if there is anyone out there who has seen a thing or two who would point me in the right direction to figuring out what I’ve got.
Thanks!
11 replies so far
View Johnny7's profile
Johnny7
347 posts in 1000 days
#1 posted 04-01-2016 05:13 AM
It would sure help if we could see an image or two.
jkdavies
5 posts in 696 days
#2 posted 04-01-2016 08:22 PM
Here are a few pictures. They aren’t the greatest. In the first two pics the plane is still dirty, and the others are of the castings on the bed after soaking a bit in vinegar.
View Don W's profile
Don W
18611 posts in 2477 days
#3 posted 04-03-2016 04:52 PM
I’ve posted a little info and some links here, http://www.timetestedtools.net/2016/01/26/brands-other-than-stanley/
jkdavies
5 posts in 696 days
#4 posted 04-03-2016 05:03 PM
Thanks for the info Don. Here are a few more pics of the 4 1/2. I found a few more “S” and “B” castings on various pieces, which makes me think some type of Stanley, but I don’t know.
View DirtyMike's profile
DirtyMike
637 posts in 811 days
#5 posted 04-11-2016 02:56 AM
i have a No. 6 with the same markings, it has a sweet heart iron, but no patent #s or brand name on the bed.
View SuppressiveFire's profile
SuppressiveFire
49 posts in 944 days
#6 posted 04-11-2016 05:13 AM
That looks earlier then the SW logo Stanley’s. What does the logo on iron show? Can I see picture of that and lever adjuster? Maybe it’s a type 7
jkdavies
5 posts in 696 days
#7 posted 04-11-2016 05:41 PM
There doesn’t appear to be a logo on the iron, and I thought it may have been a type without a lever adjuster, but on further inspection I think it may just be missing. Plus, it looks like you would have to go way back to have a plane from before Stanley started putting lever adjusters on. You can see in the picture there is a pin where it appears it was attached, although the setup looks a little different than it does on the no. 4.
Don W
#8 posted 04-11-2016 09:57 PM
Your plane is definitely a mix of type 7 and 8 parts. I could very well have come from Stanley that way around 1900, or someone could have changed some parts. You’ll never know.
jkdavies
5 posts in 696 days
#9 posted 04-11-2016 10:29 PM
I appreciate the help! I know it’s not anything to write home about, but it’s pretty neat to find something that old that was likely used by family and clean it up a bit. I’ll be on the lookout for a lateral adjustment lever to see if I can replace it. I had no idea it was that old because as far as I can tell the no. 4 I found with it is from the 50s. Dad also has a couple of antique wooden bedded planes sitting in a cabinet that likely had the same owner. One is long enough to be a jointer, but I haven’t looked for any markings. I just know the irons just wedge in the throat. Might be worth a little more investigation.
Don W
#10 posted 04-11-2016 10:42 PM
A lateral should be easy to find. You want to be careful, the history of these can become pretty addicting pretty fast.
View Aidan1211's profile
Aidan1211
198 posts in 736 days
#11 posted 04-18-2016 04:40 PM
Clean out the depth adjuster Knurl inside see if it says anything. A lot of what I’m seeing screams Union but some if it doesn’t. Could be an all original frankenplane! I’d clean it up tune it and put it to work!
-- its better to plan on the task at hand than actually doing it........ You look smarter.
