How do I use this Black & Decker Deluxe Router Guide #76-234 ?
Forum topic by mahdee posted 03-31-2016 05:40 PM 5014 views 0 times favorited 11 replies Add to Favorites Watch
View mahdee's profile
mahdee
4045 posts in 2008 days
03-31-2016 05:40 PM
Topic tags/keywords: jig
I bought this Black & Decker Deluxe Router Guide #76-234 and can’t figure out how it is used to cut circles with. It says it can cut from 2-1/2” to 2’. There is a pin at the end of it that seem to be upside down. Do I put a nail through that for cutting circles?
Thanks
-- earthartandfoods.com
11 replies so far
MrUnix
7114 posts in 2440 days
#1 posted 03-31-2016 06:22 PM
Flip it over so the pin sticks down. It’s described in the manual… do you have one?
mahdee
#2 posted 03-31-2016 07:10 PM
Thanks MrUnix,
The picture is showing it being up. Is that when it is being used as a guide instead of circle cutter?
MrUnix
#3 posted 03-31-2016 07:20 PM
- mahdee
Yes… normally the guide is attached (using the two rods to the base) in the upright position – with the rods on top of the guide. To use if for circle cutting, you slide it off the rods, flip it over, and slide it back on the rods so they are then under the guide, and the pin is facing down. Then you drill a 1/8 inch hole at least 3/8 inch deep in the center of the circle, and place the pin in it. Here is the relevant diagram from the manual:
mahdee
#4 posted 03-31-2016 07:31 PM
Great… Thanks again.
View JoeinGa's profile
JoeinGa
7740 posts in 2248 days
#5 posted 03-31-2016 08:46 PM
Geeze, I had one of those about 20 years ago. Had no idea what it was and I’m pretty sure I threw it away.
mahdee
#6 posted 04-01-2016 01:06 AM
Ha ha, Joe.. for a guide and circle cutter for like $20 you may want to get you another one.
13641 posts in 3582 days
#7 posted 04-01-2016 01:28 AM
be sure to hold the pin part down with you hand
so the rig doesn’t jump out
and scatter with the spinning bit
holding the rig lower down
help to keep it from tilting over too
mahdee
#8 posted 04-01-2016 12:12 PM
Wow David. That sounds scary holding the router with only one hand. Is there a better solution than that?
View Fardo's profile
Fardo
2 posts in 144 days
#9 posted 08-31-2018 06:25 PM
I really need the manual for the B&D Deluxe Router Guide 76-234. Can anyone send me a copy? Thanks!
mahdee
#10 posted 08-31-2018 07:44 PM
I can send you some pictures of how it works.
Fardo
2 posts in 144 days
#11 posted 08-31-2018 10:42 PM
Great! Send to richmondscribe@verizon.net….and thanks!
