Troubleshooting a Comet II Lathe, bouncing motor.
« back to Woodturning forum
Forum topic by Woodknack posted 03-31-2016 03:03 AM 1410 views 0 times favorited 24 replies Add to Favorites Watch
View Woodknack's profile
Woodknack
11479 posts in 2344 days
03-31-2016 03:03 AM
Topic tags/keywords: comet ii
So I’m working through this used Comet 2 I bought, mostly it involved catching up on overdue maintenance. But the motor is bouncing and I’m not sure what is causing it. It’s worse when the belt is farthest from the motor, has the most leverage. I made a video that shows the problem better than I can ever explain it. You can see it best around 10 seconds in. Maximize the video to see it best. Set screws in the pulleys were checked/tightened. Bolt on backside of motor was tightened. Problem is worse when lathe is on slowest pulley configuration (belt farthest from motor).
View on YouTube
24 replies so far
View HapHazzard's profile
HapHazzard
116 posts in 832 days
#1 posted 03-31-2016 12:01 PM
If I had to guess I’d say the upper pulley is moving. When you show it in low gear, the thumping sounds like it’s about once per revolution of the headstock shaft. The motor is turning much faster, so it doesn’t seem to have anything to do with the motor. Either the set-screw is loose or one of the bearings is seriously bad. Try taking the belt off and see if you can wiggle the pulley while holding the handwheel.
-- Unix programmers never die; they just > /dev/null
View dhazelton's profile
dhazelton
2754 posts in 2260 days
#2 posted 03-31-2016 12:44 PM
It just looks like a flimsy mount to me.
View Roger's profile
Roger
20923 posts in 2768 days
#3 posted 03-31-2016 12:55 PM
Bearings maybe?
View kiefer's profile
kiefer
5618 posts in 2631 days
#4 posted 03-31-2016 02:03 PM
How about the upper pulley out of round or the bore too large pushing the pulley of centre when the set screw is tightened or bad belt ?
Klaus
-- Kiefer https://www.youtube.com/user/woodkiefer1/videos
View LeeMills's profile
LeeMills
522 posts in 1265 days
#5 posted 03-31-2016 03:22 PM
Just guessing but may be…
the “motor mount screws” are loose (3 screws) item 12…
too much tension on the belt… should only be the pressure from a couple of fingers, then lock down.
http://www.teknatool.com/products/lathes/CometII/Downloads/Comet%20II%20Manual%20Final%20_19%20April%202013.pdf
Other items on page 24 of manual.
Woodknack
#6 posted 03-31-2016 05:44 PM
- LeeMills
I checked both, the screws were tight but I removed, cleaned, and reinstalled them but I haven’t remounted the motor yet. I also removed the bottom pulley and am realigning it.
If I had to guess I d say the upper pulley is moving. When you show it in low gear, the thumping sounds like it s about once per revolution of the headstock shaft. The motor is turning much faster, so it doesn t seem to have anything to do with the motor. Either the set-screw is loose or one of the bearings is seriously bad. Try taking the belt off and see if you can wiggle the pulley while holding the handwheel.
- HapHazzard
Klaus
- kiefer
I’ll put a dial indicator to it later and check.
The belt looks okay.
- dhazelton
Definitely but it still should not be doing that.
Bearings maybe?
- Roger
The bearings are coming due. I don’t think they are causing this but I could be wrong.
View JoeinGa's profile
JoeinGa
7735 posts in 1971 days
#7 posted 03-31-2016 08:35 PM
Just curious… Is the lathe bolted down to the bench?
Woodknack
#8 posted 04-01-2016 04:02 AM
There are no problems and no runout with the motor, motor mounts, motor shaft, or bottom pulleys that I can find. The pulleys are aligned. The belt is properly tensioned. So the problem pretty much has to be in the top of the headstock or the belt (although the belt looks fine). Not bolted down Joe,
I checked each part with a dial indicator. There is some small runout, 5 thous, but nothing I wouldn’t expect for a used lathe in this price range. I pulled on the spindle with the DI measuring and it barely moved but it was tricky getting the DI and my hand in there. I’ll contact Teknatool tomorrow and see what they say.
View MadMark's profile
MadMark
979 posts in 1417 days
#9 posted 04-01-2016 05:19 AM
You’re hitting a resonance with the motor mount & motor. Since you’re using variable speed DC motor, if there is a resonance at any speed, you’ll find it. The solution was at your fingertips in your video. Put a firm rubber spacer under the free end of the motor & the problem should vanish.
M
MadMark
#10 posted 04-01-2016 05:23 AM
Depends. Customers like drawers that slide and doors that open & shut properly. In kitchens I use stainless steel, for ornamentals usually wood. In any case if the cust asks, I do it their way. If your stuff is functional, who cares?
M
HapHazzard
#11 posted 04-01-2016 01:21 PM
If there isn’t any appreciable headstock runout and both pulleys are tight, you’re definitely looking at bearings. Probably the cage has worn out in one of them and it’s letting the balls make contact, which causes a regular, rhythmic jump in the turning resistance. You may or may not be able to feel it if you loosen the belt and turn the handweel.
Woodknack
#12 posted 04-01-2016 05:33 PM
If there isn t any appreciable headstock runout and both pulleys are tight, you re definitely looking at bearings. Probably the cage has worn out in one of them and it s letting the balls make contact, which causes a regular, rhythmic jump in the turning resistance. You may or may not be able to feel it if you loosen the belt and turn the handweel.
- HapHazzard
I think you’ve nailed it. I sent the video off to Teknatool but I’m ambivalent in my hope they will reply. Reviews say Teknatool’s customer service is nonexistent but I’m happy for those people to be proven wrong. Some of those reviews also speak to premature bearing replacement. So now, both my lathes are down needing a bearing change. Hell, I bought this Comet in part so I could use it and not be out a lathe while working on my old Delta, that and it was a steal of a deal.
HapHazzard
#13 posted 04-01-2016 10:39 PM
Can I recommend some good, cheap, precision bearings? These are the ones I just put two of in my Excelsior.
http://www.amazon.com/6005-2rs-Premium-Bearing-Bearings-ABEC3/dp/B00XRWGLGA
They’re asking $16.99 plus $5.99 shipping for ten. If both lathes take the same bearing, you’ll use 4 right off the bat.
You don’t need to buy bearings from the manufacturer. From what I’ve seen, none of them actually use precision bearings anyway. As long as the numbers are the same, it’s the same bearing, and you only need to worry about the “6005” part. Some lathes come with 6005Z or ZZ, which just means they have metal shields instead of rubber dustcovers, but I really don’t see why you’d need a shielded bearing on a lathe.
View MrUnix's profile
MrUnix
6586 posts in 2163 days
#14 posted 04-01-2016 11:29 PM
Lesson learned and why I always recommend replacing bearings on any new to you used machine. You have no idea what use/abuse it may have seen in it’s lifetime and bearing are cheap insurance. As always, yank them to figure out what you got, measure them to be sure, and give Lynne a call over at Accurate to hook you up :)
Woodknack
#15 posted 04-02-2016 01:48 AM
If the bearings are easy to replace, nothing wrong with cheap. But nothing wrong with using a quality bearing either especially if they are not easy.
Years ago I read a great article on bearings, told me more than I would ever have wanted to know, but it said that ZZ, metal shielded, bearings are what you want for machinery because they provide more protection against particles/dust and less friction. I’m no bearing expert but all my machines have metal shielded bearings.
