Drum Making....tried it?
Forum topic by Hyperhutch posted 03-12-2010 03:45 AM 1165 views 0 times favorited 3 replies Add to Favorites Watch
View Hyperhutch's profile
Hyperhutch
63 posts in 3126 days
03-12-2010 03:45 AM
So, I have been playing with the idea of trying to make a drum, such as a djembe or bongos. Has anyone here tried anything like this before? Thanks!
Hutch
-- I hope the volume of shavings one creates is directly related to the probablility of one's success, cuz if so I've got it made!!
3 replies so far
View kidi's profile
kidi
15 posts in 3089 days
#1 posted 03-12-2010 04:39 AM
Check out some of my projects. I have been making drums and some other percussion instruments for a few years and would love to help.
-- paul, mmsmarimbas.com
Hyperhutch
#2 posted 03-12-2010 06:37 AM
Cool stuff! What you have pictured in your projects isn’t far from what I was envisioning. Thanks!
Hutch
View Olaf Gradin's profile
Olaf Gradin
73 posts in 3716 days
#3 posted 03-19-2010 07:25 PM
I didn’t make the shell I’ve shown in my projects list (I finished it and did the rope tuning and such), but I am familiar with the process. The simplest to get started on is the ashiko. It’s conical in shape, so only has a single beveled-angle requirement (taper cut with tilt on table saw). The djembe pictured has three such parts; the foot is separate until glued up after the steel ring is placed. The bowl is constructed from two separate cones, one very short, glued up on a rabbet (routed with a circular template).
If you’re going to attempt the stave-construction method used a lot in the US, use a digital gauge to measure your bevel and angle. You want your glue-ups to be very precise to squeeze out any gaps when clamping.
-- It takes a viking to raze a village. &mdash Blog'r: http://www.gradin.com
