Cutting Long Boards to Narrower Pieces
Forum topic by Antonis512 posted 03-31-2016 12:24 AM 905 views 0 times favorited 4 replies Add to Favorites Watch
View Antonis512's profile
Antonis512
3 posts in 784 days
03-31-2016 12:24 AM
Hello all!
During the years, I have read a lot of good information in this forum and now I would like to ask something for which I do not know the terminology in English (English is not my native language). Please forgive me for making my point with a lot more words than maybe what is needed.
I will work this project using kiln dried beechwood. I need to cut 2in x 6in or 2in x 8in boards of a length of 10ft, to pieces that will give me a final product which is cylinders, 1 3/8in in diameter and 7ft of length.
We all know that if one cuts such long pieces, no matter if the wood is kiln dried, they will bend. I was thinking of cutting these wide boards in half, then cutting pieces of 2in x maybe 2 1/2 in. Let those relax for some days, then come back with a long marking string to mark straight lines, cut them and square them to the desired dimensions.
Does anyone have a better suggestion or a link that will help?
Thank you for even reading through this post!
View jerryminer's profile
jerryminer
923 posts in 1438 days
#1 posted 03-31-2016 02:24 AM
I think you are on the right track (“on the right track” being an American expression meaning you’re thinking correctly)
To the extent that you can either select straight-grained pieces, or make your initial cuts follow the grain to keep the grain running straight along the length you will be better off.
View chiseler's profile
chiseler
124 posts in 885 days
#2 posted 04-02-2016 05:40 AM
your best results will obtained using quarter sawn
-- Scott.Triangle,NY Becareful and don't forget...They cut meat too! Ask me how I know
jerryminer
#3 posted 04-02-2016 08:40 AM
- chiseler
There is no quarter sawn in 2×2, but there is straight(ish)
Antonis512
3 posts in 784 days
#4 posted 04-04-2016 09:21 PM
Thank you!
I will go select wood tomorrow. I will be flipping boards until they get tired of me!
I will try to get something as close to quarter sawn as possible but as Jerry said, it is not likely to find one in a 2in thick European beechwood. It has to be a laaaaaaaaaaaaaaaaaaarge tree. I have come across some 2in thick Iroko looking almost quarter sawn and that was a surprise back then.
