CBN grinding wheel
« back to Woodturning forum
Forum topic by Clarkie posted 03-30-2016 04:38 PM 1881 views 0 times favorited 36 replies Add to Favorites Watch
View Clarkie's profile
Clarkie
453 posts in 1744 days
03-30-2016 04:38 PM
Good afternoon fellow woodmen and wimmens. I am looking for some simple feed back on the CBN wheel for sharpening. How does it perform and are you able to actually get a good edge even being a novice sharpener? Where is the best place to purchase one, and do you need to go to the 8” or is the 6” sufficient? I have found them from 179.00 to 69.00 for the 6”, I’d appreciate any help and instruction that is available. It’s one thing to watch a video and then it’s something else to hear from one who is fresh into sharpening. I tried the Tormek and even though I did my best, I still felt the edge wasn’t the best as compared to the guys in the videos.
36 replies so far
View cdaniels's profile
cdaniels
1320 posts in 1404 days
#1 posted 03-30-2016 04:43 PM
i’m a new turner (about 2 years). I used an 8” rikon slow speed grinder with standard wheels for a while, ruined a bowl gouge when a wheel blew up on me and scared my wife into buying my cbn wheels. I bought them from the site below, same set that I linked and it blew my mind how much of a difference it makes. smoother to sharpen, cleaner edges, no heat buildup and they NEVER wear out. I will never be able to say enough about how happy I am going with cbn wheels, I would never go back to anything else. Definitally worth the purchase.
http://woodturnerswonders.com/collections/radius-edge-cbn-wheels/products/cbn-wheel-pair-80-and-180-grit
-- Jesus was a carpenter... I'm just saying
View putty's profile
putty
1179 posts in 1509 days
#2 posted 03-30-2016 04:52 PM
I got the same set for Xmas. I’m a novice turner and always have had trouble sharpening. I have the rikon slow speed grinder also with the wolverine jig. Tools are getting very sharp and its a joy to use sharp tools. I mostly use the 180 grit. The wheels run very true.
-- Putty
View TheDane's profile
TheDane
5365 posts in 3566 days
#3 posted 03-30-2016 05:12 PM
Here is a link to the review I wrote over two years ago …
http://lumberjocks.com/reviews/3742
Wouldn’t do anything different if I were purchasing today.
View Bruyet's profile
Bruyet
40 posts in 1046 days
#4 posted 03-30-2016 09:29 PM
I’ve only been turning for a year and a half, and I can honestly say that the CBN wheel has had the biggest impact on my abilities. I also have the Wolverine jig. The repeatability is incredible, and if you can’t consistently sharpen your tools you can’t become a better turner, IMO.
View JohnKos's profile
JohnKos
1 post in 1222 days
#5 posted 03-30-2016 09:30 PM
+1 for Ken at woodturnerswonders !!!!
Clarkie
#6 posted 03-30-2016 09:54 PM
First of all thank you all for your responses. I have found a site that offers 2 wheels for 99.00 each. You get a 6” wheel with a 1/2” hole. Now, beside the wheels, do I get the Wolverine sharp jig, and then I should be good to go, right? I have a 3450rpm grinder, many have said speed doesn’t really factor in, whether high or low, and it has a 1/2” arbor.
Clarkie
#7 posted 03-30-2016 11:44 PM
Hey Gerry, thanks for forwarding your review it was very helpful.
cdaniels
#8 posted 03-31-2016 02:01 AM
speed is more a factor for the old style wheels because the heat ruins the tempering on your tools so they won’t hold an edge if they get overheated during sharpening. with cbn wheels it won’t be as much an issue. not all CBN wheels are created equal though, keep that in mind. you should have the wolverine and the varigrind. it does get a little expensive to get set up in the beginning but if you get the good stuff you will never have to buy them again!
View bigJohninvegas's profile
bigJohninvegas
417 posts in 1365 days
#9 posted 03-31-2016 02:02 AM
i purchased the 180 grit wheel from woodturnerswonders.com last year after reading the review from the TheDane.
It is working perfect, and I believe it to be the best lathe accessory I have ever purchased.
-- John
View TheFridge's profile
TheFridge
8852 posts in 1389 days
#10 posted 03-31-2016 02:09 AM
A bunch of enablers in here. Guess I need to save my pennies.
Clarkie
#11 posted 03-31-2016 02:53 AM
Do any of you guys sharpen your plane irons or chisels with these wheels? Thanks again for all the feed back, huge help.
View mramseyISU's profile
mramseyISU
531 posts in 1448 days
#12 posted 03-31-2016 12:55 PM
I don’t know anything about CBN for sharpening tools but I can tell you that in my last job all of the gear grinding we did was done with those wheels (just a lot bigger).
-- Trust me I'm an engineer.
View RichCMD's profile
RichCMD
393 posts in 1844 days
#13 posted 03-31-2016 01:03 PM
I bought the a set of CBN wheels and a Rikon grinder from Ron Brown at the Woodworking Show in Baltimore in January. This replaced an older grinder with old style wheels that I seemed to constantly have problems keeping in balance. I love the new set up. I find it is much easier and faster to sharpen my turning tools with the CBN set up. So far, I have used this exclusively for turning tools.
-- Ride the bevel!
TheDane
#14 posted 03-31-2016 01:40 PM
- Clarkie
Only if they are HSS (or harder). I have heard that carbon steel will clog CBN wheels.
View jeff's profile
jeff
1063 posts in 3368 days
#15 posted 03-31-2016 02:56 PM
I purchased my CBN wheels from woodturnerswonders also after reading TheDane’s review.I couldn’t be happier.
-- Jeff,Tucson,Az.
showing 1 through 15 of 36 replies
