Turning my small garage space into a woodshop
Forum topic by Evowood posted 03-30-2016 03:34 PM 1964 views 0 times favorited 27 replies Add to Favorites Watch
View Evowood's profile
Evowood
29 posts in 795 days
03-30-2016 03:34 PM
Topic tags/keywords: shop woodworking layout
I have stopped my car “hobby” and decided to get deeper into woodworking. I like the be able to make things, and woodworking is the best path to creating usable items. Over the last month I have been trying to pick up some tools that can increase what I can actually do with the limited space and time that I have. Over the last month I have picked up the following.
Harbor Freight Dust Collector
Dust Collector Filter cartridge
55 Gallon Plastic Drum
Rocker DIY dust collector kit
Dewault 735X Planer
Delta 37-715 Hybrid table saw with large outfield table
Powermatic 54A Jointer
Millers Falls #9 smoothing plane
Japanese back saws
Waterstones for sharpening
I also already have a modified stanley bailey block plane, a LV low angle jack plane, a small gentlemen saw, a set of 1/4-1” bevel edged chisels, compound miter saw, jig saw, cicurlar saw, palm sander, and hand held belt sander. I am still looking to add some additional mortise chisels. I have some Witherby chisels nearby that I am going to refurb if I can get them. I also installed 4 4’ T5 HO lights above my work area. These provide a plenty of light for the area I will be working in.
My next major tool purchase will be a 12-14” bandsaw. I am thinking of getting a 12” craftsman bandsaw just for cutting curves, and saving up for a laguna 14/Twelve or BX. I can get the craftsman right now used for $100-150. Until I can get a nice bandsaw for resew I will just waste wood by using the planer to get it to the dimensions I want. I am also going to keep my eye out on CL for a decent belt/disc sander.
Here are some pictures to show what I am starting with. The full album is available here.
https://www.icloud.com/sharedalbum/#B0F532ODWBGxJd
My Lists of task are as follows:
Remove shelf in back corner and install dust collector
Build cyclone for dust collector
Add 2 220v outlets
Assemble Table saw
Finishing building 3 more drawers fro my cabinet under my basic workbench.
Finish building my woodworking bench
Build stand for the planer
Remove workbench on side of garage under window
Build either a fixed or rolling wood rack. I am thinking rolling with sheet goods on one side and boards on the other
Finish rack on top of basic workbench. I am thinking of adding a 6” tall section for storing 2’ or scraps.
CLEAN IT ALL UP
Cut stuff
Feel free to add comments and suggestions. I am new to all of this so ANY advice is great to have.
Thanks, and enjoy
27 replies so far
View ste6168's profile
ste6168
255 posts in 1170 days
#1 posted 03-30-2016 06:40 PM
Compared to the space I have, that looks more like a “large” garage space to me!
View Minorhero's profile
Minorhero
373 posts in 2603 days
#2 posted 03-30-2016 07:00 PM
Well you are certainly off to a great start tooling wise and you have a pretty nice space. Lots of folks out there are doing quality work in much smaller spaces. My advice is hold off on a bandsaw till you make a project that really needs it. You already have a jig saw so you can make curves as needed, there doesn’t sound like much need to buy an interim bandsaw till you save up to buy the bandsaw you really want. Just start saving for that now. In the meantime also consider installing more then two 220 outlets. Not sure how many 110 outlets you have in there on how many different circuits but you will probably want a few extra of those. The HF dust collector will essentially need to run on its own circuit whenever you are also running a 110 volt tool and then you may also want to run some other equipment at the same time like a computer, a fan, etc. If you are installing new electric put the outlets over 4 feet off the ground, that way you can lean a sheet of plywood against the wall and not cover up your outlet.
Evowood
#3 posted 03-30-2016 07:12 PM
I already have 1 220 outlet, so I am adding one for the dust collector and one for the jointer. That is good advice on the bandsaw. The only reason I would by the smaller band saw is because a friends dad is selling it. Otherwise I wouldn’t even consider it. I am working on a layout in sketchup right now. I will post a pic when it is done.
View Antonis512's profile
Antonis512
3 posts in 786 days
#4 posted 03-30-2016 07:57 PM
I was working in a small workshop for years (smaller than your garage). If I may share an opinion:
Plan to put everything you can in drawers or behind closed doors. It will be much easier to clean up and find things. I tried a dust collector in the workshop but the noise was such an issue, that I ended up using it only when I was cleaning (and that was rare as I had to keep working until late every day). I do not know how youtubers keep such clean workshops with every tool hanging on the wall, exposed to dust…
View helluvawreck's profile
helluvawreck
31082 posts in 2865 days
#5 posted 03-30-2016 08:23 PM
It’s always enjoyable to set up a new shop and you have the makings of a nice one. I hope that it all goes off without a hitch. Congratulations and welcome to Lumberjocks.
helluvawreck aka Charles
Evowood
#6 posted 03-30-2016 08:28 PM
Here is the layout for the shop that I would like to do. Still need to add the planer.
View Rentvent's profile
Rentvent
151 posts in 847 days
#7 posted 03-31-2016 03:47 AM
Great drawings. Now add the dust collector hoses and power connections.
View McFly's profile
McFly
273 posts in 1026 days
#8 posted 03-31-2016 04:16 AM
A small garage he says…there are prison cells are larger than my shop, but I enjoy my time in there a helluva lot more than prisoners do!
Looks like you’re off to a decent rolling start.
View BEWoodworks's profile
BEWoodworks
37 posts in 848 days
#9 posted 03-31-2016 03:16 PM
It has been mentioned but I would agree with skipping a smaller bandsaw, since you have a jigsaw. They are limited in their use and you will outgrow it quickly. I have the same jointer. You will like it, with the exception possibly of dust collection. I have done a few reorganizations and have always needed more room for the jointer than I accounted for. Plenty of infeed and outfeed space is required.
Buy tools as you need them for projects you are actually building, not what you think you will need. Will save you $ in the long run. Good luck.
Evowood
#10 posted 03-31-2016 03:34 PM
Haha, I love all the comments on it not being a small garage. I know it is “adequate” for me right now, but my goal is to build a 16×20 workshop detached from the house so my wife will actually let me use power tools while the kids are sleeping.
Thanks for the input on the bandsaw. It is probably a good idea to not have it right now, as was mentioned. It would just take up space while I don’t use it.
I did just notice last night that the jointer does not have a dust collection port. Has anyone added one to it?
View pete724's profile
pete724
55 posts in 807 days
#11 posted 04-01-2016 09:44 AM
Router?
Evowood
#12 posted 04-01-2016 01:43 PM
Haha, yes, I do have a router. PC 1 3/4 HP with no plunge base. I also have a rout r lift that I have yet to install in anything since it was going to go into my old table saw, but now I have a new one.
ste6168
#13 posted 04-01-2016 05:48 PM
Thanks for the input on the bandsaw. It is probably a good idea to not have it right now, as was mentioned. It would just take up space while I don t use it.
- Evowood
What are the dimensions of the current space? Pictures can be deceiving. Looks like you are off to a very good start, machinery and layout wise… Here is a a link to some info on my shop and how it is setup. The picture toward the bottom is the most up-to-date.
http://steinwoodworks.weebly.com/shop-tour.html
Evowood
#14 posted 04-06-2016 05:29 PM
The dimensions are
8×8 Area + 11×10 Area.
Here are some pictures of the closet that I am building for the DC. Above it will be used as storage for some kind of wood :). I will be building the top, and maybe the door today. The door will be flush mount and drywalled. The door will have a wheel on the bottom since I am going to make it out of 2×4. I will probably store my clamps on the door.
Electrical is done as well. Added a dedicated circuit for the DC, a new 120 circuit with 4 outlets that I will use for my 120 V devices, and a dedicated 220v outlet for the jointer. In total I have 5 120 outlets and 2 120 outlets now. There isn’t much room left in the breaker panel for much else. But since I will never use more than 2 220, and almost always 1 220v device at a time, I don’t need more than two. I also have the DC wired so I can easily convert it to a 220v 20a circuit, just in case I upgrade the DC. Granted if I did that I would have probably built a detached shop.
View Notw's profile
Notw
642 posts in 1752 days
#15 posted 04-06-2016 07:44 PM
Good thinking putting the dust collector in the closet, I wish I had the space in my one car garage shop to add a closet for mine.
