Rolair Air Buddy AB5
Forum topic by bigarm posted 03-29-2016 11:39 PM 543 views 0 times favorited 3 replies Add to Favorites Watch
View bigarm's profile
bigarm
62 posts in 1127 days
03-29-2016 11:39 PM
Will this compressor run an 18 gauge nail gun? I have a bigger, noisier, compressor for most things but sometimes need something very portable.
3 replies so far
View rick1955's profile
rick1955
264 posts in 1457 days
#1 posted 03-30-2016 12:02 AM
And more. I have a Campbell Hausfeld 2 gallon compressor that will work fine with a 16 gauge finish nailer. A bit noisy but weighs 10 lbs. compare the specs of a compressor and specs of the nail gun and you can answer the question yourself.
-- Working smarter with less tools is a true crafts person...
View MrUnix's profile
MrUnix
6766 posts in 2225 days
#2 posted 03-30-2016 12:08 AM
Almost any compressor will run a nailer… they don’t need huge amounts of CFM, just sufficient pressure (typically 50-60 psi). That compressor only has a 1 gallon tank though, so if you are doing something like flooring, it might cycle quite a bit.
View MrRon's profile
MrRon
4795 posts in 3269 days
#3 posted 03-30-2016 04:53 PM
I have a California Air compressor that has a 1.6 gal. tank and puts out 1.1 cfm @ 90 psi. It is very similar to the Rolair. It runs my 18 ga nailer for about 20 shots before it recycles. I can also get about 5 shots with my 15 ga finish nailer, so your compressor will work just fine.
