Recommendations for custom branding iron.
Forum topic by bondogaposis posted 03-29-2016 05:41 PM 635 views 0 times favorited 4 replies Add to Favorites Watch
View bondogaposis's profile
4629 posts in 2280 days
03-29-2016 05:41 PM
Topic tags/keywords: question
I need a new branding iron, any recommendations?
-- Bondo Gaposis
View knotscott's profile (online now)
7929 posts in 3304 days
#1 posted 03-29-2016 07:21 PM
This is really a “work-around” from your real question, but I couldn’t justify the cost of a branding iron, so I had a rubber stamp made. It was less than $8 about 12 years ago. It works best if applied under any clear coat.
View bobasaurus's profile
3391 posts in 3113 days
#2 posted 03-29-2016 07:30 PM
I’ve heard good things about these guys:
If you’re good with 3D design, you can also draw one up and get it 3D printed by ShapeWays cheap when they have a new customers coupon. I drew mine to thread onto an existing soldering iron I had from a previous brand:
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View MrUnix's profile
6467 posts in 2128 days
#3 posted 03-29-2016 07:40 PM
There was a pretty good thread around here a while back that discussed it in great detail, and had some pointers to reasonably priced solutions. The problem I have with a fixed iron is that you are limited to size. A largish brand is good for big stuff, but not for something like a small lidded box or bowl… and a smaller one for those would not be ideal for larger stuff. My solution (after giving up the sharpie) was to use the heat transfer method – from logos/brands printed on a laser printer with standard copy paper. You can print them out any size you want to suit the project, and transfer the image to the piece using a slightly modified soldering iron.
View Dabcan's profile
255 posts in 2600 days
#4 posted 03-29-2016 11:56 PM
I had these guys make mine:
Was super happy with the result, highly recommended. I got one that you plug in as I do production runs and I found it the easiest way to go.
-- @craftcollectif ,,
