Curved plywood
Forum topic by woodworkingdrew posted 03-29-2016 01:08 AM 504 views 0 times favorited 2 replies Add to Favorites Watch
View woodworkingdrew's profile
189 posts in 1539 days
03-29-2016 01:08 AM
My buddy and I assembled this cabinet and noticed that the plywood was bowed. Wondering if anyone else has run into this and what the fix would be if any. Thanks
-- Andrew, California
2 replies so far
View 01ntrain's profile
243 posts in 1000 days
#1 posted 03-29-2016 01:21 AM
I would speculate that your vertical pieces are a tad to long or you measured correctly and your dadoes are not deep enough. But, it you’re putting cross pieces in, you really shouldn’t have an issue any longer. Just bend the vertical pieces plumb, measure the cross-pieces, cut, install and you should be OK.
View conifur's profile
955 posts in 1081 days
#2 posted 03-29-2016 01:48 AM
Ditto that and if you rabbited the frame in back to put the back in should take care of it too. If putting on a face frame that will take care of that too.
