Quick finishing question.
Forum topic by Jonathan posted 03-10-2010 07:31 PM 956 views 0 times favorited 10 replies Add to Favorites Watch
View Jonathan's profile
Jonathan
2608 posts in 3047 days
03-10-2010 07:31 PM
I am making an impromptu gift for someone we’re going to visit, so I need the finish to dry/cure quickly.
The item is a little ring holder made of walnut. I’m going to add a dowel in the center. Not sure what I’m going to sand to, and maybe that’ll depend on the finish?
I won’t be able to apply the finish until tonight and we’re flying out tomorrow morning.
I have Watco Danish Oil and Zinsser shellac at home. I was also considering SealCoat.
That’s probably only enough time for 1-2 coats.
So, what would you sand to and what finish would you apply?
We won’t actually be giving it to her until Friday, but I’d imagine she’ll start using it Friday night.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
10 replies so far
View lew's profile
lew
12056 posts in 3751 days
#1 posted 03-10-2010 07:36 PM
Wipe on poly
View stefang's profile
stefang
15881 posts in 3330 days
#2 posted 03-10-2010 07:43 PM
I agree with Lew. If it will be used a lot Danish oil or shellac won’t stand up very well. The gift will still smell of poly when you deliver it. A good alternative could be spray lacquer which normally dries totally in about 3 hours and probably with less after smell than poly.
View hObOmOnk's profile
hObOmOnk
1381 posts in 4124 days
#3 posted 03-10-2010 09:04 PM
Shellac will allow you to apply two or three coats in one day.
It is more than durable enough for small craft items.
-- 温故知新
View wisno's profile
wisno
88 posts in 3007 days
#4 posted 03-10-2010 09:08 PM
I agree with Mike,
The poly will take long time to dry, at least 1 or 2 days.
It is better if you use nitrocellulose clear coating.
-- http://www.wisnofurniturefinishing.com/
27250 posts in 3818 days
#5 posted 03-10-2010 09:20 PM
If I were doing a project like this and needed a quick finish, as Randy said, you can apply multiple coats of shellac in a very short time frame. I have put as many as 6 on in a single day. And the spray lacquer will work as well. It just depends on which one you have available and are comfortable with.
Jonathan
#6 posted 03-10-2010 10:16 PM
Thanks for all the response so far!
I ended up bringing a box full of finishing stuff with me to work so I can work on it later when it’s slow. That’ll give me a bit of precious time. I brought everything with me to finish this project.
Maybe an ignorant question, but could I do a coat or two of shellac, then spray 1-2 coats of lacquer? Should I send to 220 or go up to 320? I also brought some steel wool with me as I thought that might be best if I go the lacquer route?
Is this overkill? Should I simply pick either the shellac or lacquer or do a combo?
Jonathan
#7 posted 03-10-2010 11:38 PM
OK, so the shellac I have is not dewaxed, so I guess I won’t be putting the lacquer over it if I go that route.
I have never used shellac before, so I forgot about the waxed vs. dewaxed kinds.
Jonathan
#8 posted 03-11-2010 04:46 AM
OK, got the dowel in and clamped down. Now I’m just waiting for the Titebond III to set up.
I sanded to 80-100-150-220-320.
I think I’m going to go with the spray lacquer at this point.
It’s probably just going to be 1 or maybe 2 coats at the most, as I’m running out of time.
Jonathan
#9 posted 03-11-2010 05:34 PM
I’m sitting at the Denver airport right now with the completed project in-hand.
I got the last coat of lacquer on this morning shortly before leaving the house.
I ended up getting 3-4 coats on. 3 on the bottom and 4-coats everywhere else.
I did have a bit of an adhesion issue on the endgrain part of the base. It’s like it didn’t want to stick. After the 2nd coat, I sanded a little on the endgrain because of some minor streaking. After that is when I really had the adhesion issue. Not sure why? Should I have used mineral spirits or something else to really clean it up?
I will try to post this as a project if I can when we get to San Juan. If not, I’ll post it once we’re Stateside again.
Thanks again for all the help!
Jonathan
#10 posted 03-22-2010 06:14 PM
Thanks again for the timely advice to everyone above, I do appreciate it!
Here’s a link to the completed project, with pictures:
http://lumberjocks.com/projects/29800
