New work bench top finish?
Forum topic by alittleoff posted 03-28-2016 01:34 PM 461 views 0 times favorited 7 replies Add to Favorites Watch
View alittleoff's profile
alittleoff
539 posts in 1276 days
03-28-2016 01:34 PM
I’ve pretty much got the top of my work bench smoothed out and wanted to go ahead and put some kind of finish on it. It may be laying for awhile and I don’t want it to get stained. I’ve got some sealers on the shelf but really don’t know what to use on a work bench. The top is yellow pine. I really need help on this, I’m not good a finishing. I don’t want anything that will gum up later if I can help it. All help appreciated, thanks in advance
Gerald
7 replies so far
View dhazelton's profile
dhazelton
2767 posts in 2296 days
#1 posted 03-28-2016 01:36 PM
Linseed oil and then paste wax is all I would use. You don’t want to put a hard finish like varnish on a softwood surface that will take some abuse.
View JayT's profile
JayT
5632 posts in 2211 days
#2 posted 03-28-2016 02:33 PM
I did one quick coat of Watco Danish Oil on my softwood bench. It was just enough for a bit of protection without making it slick. Next time it gets flattened, I probably won’t put any finish on at all. For me, it’s a work surface, not a piece of furniture and the top of a workbench needs a bit of grip to it.
View OSU55's profile
OSU55
1672 posts in 1989 days
#3 posted 03-28-2016 03:57 PM
Poly thinned 1:1, keep it wet 5-10 min, wipe it off til dry.
View Cooler's profile
Cooler
299 posts in 843 days
#4 posted 03-28-2016 04:08 PM
I have a rough workbench and I put a sheet of 3/16” thick tempered hard board on the top using carpet tape.
If it ever gets too beat up I can pop off the hard board and replace it.
Tempered hard board is much harder than the regular stuff so specify that when you shop.
Its not pretty but it is effective.
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
View shampeon's profile
shampeon
1775 posts in 2183 days
#5 posted 03-28-2016 04:12 PM
I use a BLO/shellac/DNA mix. Has the advantages of an oil finish (no film, not overly slick, easy to apply, easy to touch up) but dries fast.
View TheFridge's profile
TheFridge
9477 posts in 1486 days
#6 posted 03-28-2016 04:18 PM
I use blo and wax
View bondogaposis's profile
bondogaposis
4727 posts in 2351 days
#7 posted 03-28-2016 06:15 PM
I use Poly/BLO/MS mix. Easy to maintain and dried glue pops right off.
-- Bondo Gaposis
