Shop Air lines
Forum topic by Tim08 posted 03-10-2010 02:16 PM 5594 views 0 times favorited 3 replies Add to Favorites Watch
View Tim08's profile
Tim08
12 posts in 3124 days
03-10-2010 02:16 PM
I am looking to run air lines through my shop. I have read in several locations not to use pvc, but can pex be used?
-- Measure six times before cutting
3 replies so far
Craftsman on the lake
2804 posts in 3559 days
#1 posted 03-10-2010 02:46 PM
You know, I ran copper with silver braized joints in my garage. Where the cars are. But when I redid the upstairs of the garage I needed to run air up there. Copper is so expensive now. I just purchased some long air hoses. they aren’t very expensive and come with fittings already on the ends. I ran them like wire with staples. If you buy the plastic ones they won’t rot over time like rubber. I connected them together with pipe nipples and teflon tape and they work great, Easy to install and not expensive.
View whit's profile
whit
246 posts in 4098 days
#2 posted 03-10-2010 02:54 PM
+1 to Cotl. I use the plain old ordinary dull, dry, boring, blue airhoses sold by Harbor Freight that commonly come from a country west of the Pacific known to be a nuclear superpower. Don’t attach them too tightly; depending on how they’re run, they’ll want to lay differently under pressure than they will when not pressurized. They’ll need room to move.
Whit
-- Even if to be nothing more than a bad example, everything serves a purpose. cippotus
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3407 days
#3 posted 03-10-2010 09:21 PM
When I bought the building for my door shop, it had existing PVC air lines. I don’t recommend you use it. the ease of installation is fantastic, as is the ability to change and add lines. The line is frquently blowing apart. Then you have shrapnel to deal with. It is definitely a hazard. We are slowing replacing it with galvanized pipe. Don’t use black pipe. It will rust over time which really hurts at 100 lbs of pressure as you blow dust off yourself. (Trust me, I know)
-- http://shepherdtoolandsupply.com/
