No info on old drill press
Forum topic by 7fingers posted 03-28-2016 10:03 AM 530 views 0 times favorited 3 replies Add to Favorites Watch
View 7fingers's profile
7fingers
2 posts in 695 days
03-28-2016 10:03 AM
I saved an old drill press from the junk heep that a friend was just going to toss. I can’t find anything about it on the net and I cannot seem to be able to remove the chuch any help would be appreciated. It has a plate on the front that says anco power tool heavy duty drill press Model# GDM-100A Capacity Chuck 1/2 inch Spindle UT#2 1/2 Serial number 200
https://www.flickr.com/gp/140664863@N08/a7sA61
3 replies so far
View JoeinGa's profile
JoeinGa
7733 posts in 1911 days
#1 posted 03-28-2016 01:01 PM
Looks like one of those Chinese clones. Try cranking the handle, bringing the chuck down as far as it will go. You should see a slot come down in the side of the tube. A wedged piece of metal can be driven into the slot which should jar the chuck (and spindle) loose.
View dhazelton's profile
dhazelton
2687 posts in 2201 days
#2 posted 03-28-2016 01:35 PM
70s or 80s Taiwanese. Chuck is probably driven on to the quill and must be driven off. Why do you need to remove it – are the jaws bad?
7fingers
2 posts in 695 days
#3 posted 03-28-2016 10:10 PM
I’m trying to disassemble it to cleanup the rust and figure out where a lot of noise is coming from
